Dear list,
An Australian governmental organisation short listed GeoNetwork as a
potential metadata management tool.
However, a few key requirements are missing in GN. The most important
one is the following:
Versioning
* All changes in the metadata must be tracked
* It must be possible to bring up the version of records of a
specific date/time
* It must be possible to search through the metadata the way it
was at a certain date/time
* It must be possible to show the full history of a record
Today we had a chat with Simon Pigot and we came up with the following
options for implementation:
1. Full DB approach for keeping history of changes (history table)
2. Use SVN for storage of metadata XML and take it that bit out of
the DB
3. Create a versioning add-on to GN that using SVN and some
post-change hook to store the changes into SVN
The idea of using SVN for storage has been discussed by some members of
the GN community before (I think off-line). There is a Java API for SVN
available, we've been told, so it should not be too hard to implement
that.
We prefer option 3.
Our questions are:
* What does the GN community think of this idea?
* Does this fit within the ideas of where GN should go?
* Does this conflict with any work that the ebXML team is doing
now and if so, could we team up and work together on this?
Kind regards,
Roald
Roald de Wit
Software Engineer
roald.dewit@anonymised.com
Commercial Support for Open Source GIS Software
http://lisasoft.com/LISAsoft/SupportedProducts/
