#100: FGDC metadata validation causing StackOverflowError
Reporter: mattblanchette | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: critical | Milestone:
Component: General | Version: v2.2.0 Final
Keywords: FGDC, schema, StackOverflowError |
Attempting to validate FGDC metadata with long enough strings of text (for
example 1400 characters in the Abstract) causes a StackOverflowError from
the FGDCstring regular expression "\s*\S(.|\n|\r)*" in the schema.
Replacing this regular expression restriction in the FGDC schema.xsd with
whitespace collapsed and a minlength of 1 will prevent the Error.
Before:[[BR]]
<xsd:pattern value="\s*\S(.|\n|\r)*"/>
After:[[BR]]
<xsd:whiteSpace value="collapse"/>[[BR]]
<xsd:minLength value="1"/>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/100>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
Type: defect | Status: closed
Priority: critical | Milestone: v2.4.0 RC2
Resolution: fixed | Keywords: FGDC, schema, StackOverflowError
Changes (by ticheler):
* status: new => closed
* cc: sspigot (added)
* resolution: => fixed
* milestone: => v2.4.0 RC2
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/100#comment:1>
* cc: sspigot (removed)
* cc: sppigot (added)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/100#comment:2>
