#101: RSS pubDate uses invalid date-time format
Reporter: mattblanchette | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: major | Milestone:
Component: General | Version: v2.2.0 Final
Keywords: RSS, pubDate, date, time |
RSS generated by rss-utils.xsl contains pubDate with invalid date-time
format yyyy-MM-ddTHH:mm:ss.
This causes timestamps to be incorrect for different timezones.
The RSS pubDate should follow the RFC-822 Date and Time specifications (dd
mm yy hh:mm:ss zzz), so the format "2009-04-21T00:00:01" would be "21 Apr
2009 00:00:01 EST", with the zone value depending on the appropriate
timezone.
Here is my workaround for rss-utils.xsl:
Before:[[BR]]
<pubDate><xsl:value-of select="geonet:info/changeDate"/></pubDate>
After:[[BR]]
<xsl:variable name="date" select="geonet:info/changeDate"/>[[BR]]
<xsl:variable name="day" select="substring($date,9,2)" />[[BR]]
<xsl:variable name="monthnumber" select="substring($date,6,2)" />[[BR]]
<xsl:variable name="year" select="substring($date,1,4)" />[[BR]]
<xsl:variable name="time" select="substring($date,12)" />[[BR]]
<xsl:variable name="month">[[BR]]
<xsl:choose>[[BR]]
<xsl:when test="$monthnumber='01'">[[BR]]
<xsl:value-of select="'Jan'" />[[BR]]
</xsl:when>[[BR]]
<xsl:when test="$monthnumber='02'">[[BR]]
<xsl:value-of select="'Feb'" />[[BR]]
</xsl:when>[[BR]]
<xsl:when test="$monthnumber='03'">[[BR]]
<xsl:value-of select="'Mar'" />[[BR]]
</xsl:when>[[BR]]
<xsl:when test="$monthnumber='04'">[[BR]]
<xsl:value-of select="'Apr'" />[[BR]]
</xsl:when>[[BR]]
<xsl:when test="$monthnumber='05'">[[BR]]
<xsl:value-of select="'May'" />[[BR]]
</xsl:when>[[BR]]
<xsl:when test="$monthnumber='06'">[[BR]]
<xsl:value-of select="'Jun'" />[[BR]]
</xsl:when>[[BR]]
<xsl:when test="$monthnumber='07'">[[BR]]
<xsl:value-of select="'Jul'" />[[BR]]
</xsl:when>[[BR]]
<xsl:when test="$monthnumber='08'">[[BR]]
<xsl:value-of select="'Aug'" />[[BR]]
</xsl:when>[[BR]]
<xsl:when test="$monthnumber='09'">[[BR]]
<xsl:value-of select="'Sep'" />[[BR]]
</xsl:when>[[BR]]
<xsl:when test="$monthnumber='10'">[[BR]]
<xsl:value-of select="'Oct'" />[[BR]]
</xsl:when>[[BR]]
<xsl:when test="$monthnumber='11'">[[BR]]
<xsl:value-of select="'Nov'" />[[BR]]
</xsl:when>[[BR]]
<xsl:otherwise>[[BR]]
<xsl:value-of select="'Dec'" />[[BR]]
</xsl:otherwise>[[BR]]
</xsl:choose>[[BR]]
</xsl:variable>
<pubDate><xsl:value-of select="concat($day,' ',$month,' ',$year,'
',$time,' EST'))"/></pubDate>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/101>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
