#102: FileNotFoundException in metadata insert
Reporter: chrisheyne | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: major | Milestone:
Component: User interface (web) | Version: v2.4.0 RC1
Keywords: 2.4 metadata insert |
Metadata insert of text fails with the following error:
HTTP ERROR: 400
Cannot build ServiceRequest
Cause : C:\Program Files\geonetwork\web\geonetwork\..\..\data\tmp (Access
is denied)
Error : java.io.FileNotFoundException
RequestURI=/geonetwork/srv/en/metadata.insert
Powered by Jetty://
From geonetwork log:
2009-05-05 09:22:21,853 INFO [jeeves.request] -
2009-05-05 09:22:21,853 INFO [jeeves.request] - HTML Request (from
10.8.17.130) : /geonetwork/srv/en/metadata.insert
2009-05-05 09:22:21,853 DEBUG [jeeves.request] - Method : POST
2009-05-05 09:22:21,853 DEBUG [jeeves.request] - Content type : multipart/
form-data; boundary=---------------------------265001916915724
2009-05-05 09:22:21,853 DEBUG [jeeves.request] - Accept :
text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2009-05-05 09:22:21,853 DEBUG [jeeves.request] - Session id is
1kx8k62fsz3bz
2009-05-05 09:22:21,963 DEBUG [jeeves.request] - Uploading file type:
application/octet-stream size: 0
2009-05-05 09:22:21,963 DEBUG [jeeves.request] - File is called after
simplification
2009-05-05 09:22:21,963 ERROR [jeeves.request] - Cannot build
ServiceRequest
is denied)
Stack :
java.io.FileNotFoundException: C:\Program
Files\geonetwork\web\geonetwork\..\..\data\tmp (Access is denied)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
at
org.apache.commons.fileupload.disk.DiskFileItem.write(DiskFileItem.java:416)
at
jeeves.server.sources.ServiceRequestFactory.getMultipartParams(ServiceRequestFactory.java:293)
at
jeeves.server.sources.ServiceRequestFactory.extractParameters(ServiceRequestFactory.java:240)
at
jeeves.server.sources.ServiceRequestFactory.create(ServiceRequestFactory.java:140)
at
jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:147)
at
jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:99)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:502)
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:363)
at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:766)
at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:417)
at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:230)
at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:534)
at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:879)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:741)
at
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:213)
at
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:403)
at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at
org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:522)
Steps to reproduce:
1. Login
2. Select Administration menu
3. Select Metadata insert
4. Select copy/paste
5. Enter metadata
6. Click Insert
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/102>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
