#1026: Supplied Configuration Override files do not work on Windows
Reporter: murrayh | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC0
Keywords: |
Comment(by awalsh):
Hello Murray,
I have been testing Geonetwork/ANZMEST in Windows XP environment too.
I assume you are talking about the web/geonetwork/WEB-INF/anzmest-config-
overides.xml file.
When geonetwork starts up it looks like the config. overrides are being
applied OK to files userprofiles.xml, config-lucene.xml and config-
summary.xml i.e geonetwork.log says:
2012-08-27 15:25:25,593 INFO [jeeves] - Overrides being applied to
configuration file: .*WEB-INF/user-profiles\.xml
2012-08-27 15:25:25,593 INFO [jeeves] - Adding xml elements to
profile[@name='Editor']
2012-08-27 15:25:25,609 DEBUG [jeeves] - Elements added are:<toAdd>
<allow service="metadata.creativecommons.form" />
<allow service="metadata.creativecommons.set" />
2012-08-27 15:25:25,625 INFO [jeeves.apphand] - Overriding mime-mappings
property (was set to ..\web\geonetwork\WEB-INF\mime-types.properties)
2012-08-27 15:25:25,625 INFO [jeeves.apphand] - mime-mappings property
set to C:\ANZMEST_SVN9275\web\geonetwork\WEB-INF\mime-types.properties
2012-08-27 15:25:29,890 INFO [jeeves] - Overrides being applied to
configuration file: .*WEB-INF/config-lucene\.xml
2012-08-27 15:25:29,890 INFO [jeeves] - Adding xml elements to
fieldSpecificAnalyzer
2012-08-27 15:25:29,906 DEBUG [jeeves] - Elements added are:<toAdd>
<Field name="taxon"
analyzer="org.fao.geonet.kernel.search.GeoNetworkAnalyzer" />
<Field name="credit"
<Field name="dataparam"
</toAdd>
2012-08-27 15:25:30,265 INFO [jeeves] - Overrides being applied to
configuration file: .*WEB-INF/config-summary\.xml
2012-08-27 15:25:30,265 INFO [jeeves] - Adding xml elements to def
2012-08-27 15:25:30,265 DEBUG [jeeves] - Elements added are:<toAdd>
<dataparams>
<item name="dataparam" plural="dataparams" indexKey="dataparam"
order="freq" type="string" max="100" />
</dataparams>
<taxon>
<item name="taxon" plural="taxons" indexKey="taxon" order="freq"
</taxon>
I thought the UNIX style forward slash '/' path seperators worked
OK Windows and we don't need to change them to windows style
back-slash '\' Am I missing something here?
This makes me wonder is this issue causing some ANZMEST specific services
to
not work e.g as I reported in ticket
http://trac.osgeo.org/geonetwork/ticket/1014
(xml_iso19139.mcp and xml_iso19139.mcp-1.4 services not working).
Simon,
Any thoughts on this?
Andrew
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1026#comment:1>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
