#1027: MCP version 1.5 (Experimental) shouldn't be loaded as the default schema
Reporter: awalsh | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.8.0 RC0
Component: Metadata standards | Version: v2.8.0RC0
Keywords: MCP schema |
Using GN2.8+ANZMEST MCP schemas.
Because of the schema detection logic coded into the
schema-ident.axml config. files for the MCPV1.4 amd MCP V1.5
schemas the MCP1.5 Experimental schema ends be default one.
The desired behavoir is the opposite i.e the MCP V1.4 schema
should be the default.
Suggested way to fix (Thanks to Ian and Simon!) is as follows:
In the mcp-1.4 schema-ident.xml we set:
<autodetect xmlns:mcp="http://bluenet3.antcrc.utas.edu.au/mcp"
xmlns:gmd="http://www.isotc211.org/2005/gmd"
xmlns:gco="http://www.isotc211.org/2005/gco">
<!-- catchs most MCP records as default 1.4 (except for
1.5-experimental)-->
<elements type="root">
<mcp:MD_Metadata/>
</elements>
</autodetect>
and in the mcp-1.5 experimental schema-ident.xml we set:
<elements>
<gmd:metadataStandardName>
<gco:CharacterString>Australian Marine Community Profile of ISO
19115:2005/19139</gco:CharacterString>
</gmd:metadataStandardName>
<gmd:metadataStandardVersion>
<gco:CharacterString>1.5-experimental</gco:CharacterString>
</gmd:metadataStandardVersion>
</elements>
</autodetect>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1027>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
