#103: Gast.jar is not working behind a web proxy, installation and configuration
fails.
Reporter: truk70 | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: major | Milestone: v2.4.0 RC1
Component: GAST | Version: v2.4.0 RC1
Keywords: installation proxy gast web |
When installing the geonetwork 2.4, after unpacking, the installer starts
gast.jar a Error message raises:
''ConnectException''
''Connection timed out:connect''
When gast.jar ist started manually, it exits with the same error message.
Running wireshark as shows, that gast tries to open a connection to IP
209.235.245.73 which resolves as ''mortbay.org'', the home-site of jetty.
Our desktop computers, as well as servers are behind a web proxy.
But even using -Dhttp.proxyHost=<ourproxy> didn't resolve the problem.
gast.jar with -DTRACE=true gave:
C:\Programme\geonetwork24\gast>java -Dhttp.proxy=proxy.unibe.ch
-DTRACE=true -jar gast.jar
java.net.ConnectException: Connection timed out: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at
sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown
Source)
at
sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown
Source)
at
sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at
com.sun.org.apache.xerces.internal.impl.XMLEntityManager.setupCurrentEntity(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLEntityManager.startEntity(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLEntityManager.startDTDEntity(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDTDScannerImpl.setInputSource(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$DTDDriver.dispatch(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$DTDDriver.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown
Source)
at
Source)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown
Source)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:453)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:810)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:789)
at org.fao.gast.lib.XMLLib.load(XMLLib.java:55)
at org.fao.gast.lib.XMLLib.load(XMLLib.java:47)
at org.fao.gast.lib.EmbeddedSCLib.<init>(EmbeddedSCLib.java:50)
at org.fao.gast.lib.Lib.init(Lib.java:57)
at org.fao.gast.cli.Cli.start(Cli.java:40)
at org.fao.gast.boot.Util.boot(Util.java:136)
at org.fao.gast.Gast.main(Gast.java:50)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/103>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
