#104: Metada Insert broken
Reporter: heikki | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: critical | Milestone: v2.4.0 RC0
Component: General | Version: v2.4.0 RC0
Keywords: Metadat Insert |
I tried to insert metadata using the classic Copy/Paste. The result was :
HTTP ERROR: 400
Cannot build ServiceRequest
Cause : <instalation-directory>\web\geonetwork\..\..\data\tmp (Access is
denied)
Error : java.io.FileNotFoundException
RequestURI=/geonetwork/srv/en/metadata.insert
I think that maybe, the way metadata insert works has been changed in
connection with the new File Upload function. But it seems to me that a
Copy/Paste should work as before, as there is no need at all to use tmp
files for this.
I tried this on a very recent check-out of the TRUNK sources.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/104>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
