#1041: Pressing <Enter> key instead [Search] button sends only Simple Search
request.
Reporter: vsinceac | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: minor | Milestone: v2.9.0
Component: User interface (web) | Version: v2.8.0RC0
Keywords: search button, enter key, simple search, advanced search |
When in Advanced Search mode (with more parameters than available in
Simple Search), pressing the <Enter> key instead the [Search] button sends
a Simple Search request.
Example: In Advanced Search mode, the [Search] button generates the
correct request:
http://localhost:8080/geonetwork/srv/eng/main.search.embedded?or=&phrase=&all=&without=&title=&abstract=&themekey=synop&similarity=.2&northBL=38.4720&westBL=60.5042&eastBL=74.9157&southBL=29.4061&relation=overlaps®ion=2&radfrom=&dateFrom=&dateTo=&extFrom=&extTo=&sortBy=relevance&sortOrder=&hitsPerPage=10&output=full&siteId=&group=&template=n&category=&_status=
while the <Enter> key generates a Simple Search request:
http://localhost:8080/geonetwork/srv/eng/main.search.embedded?any=synop&dummyfield=&northBL=38.4720&westBL=60.5042&eastBL=74.9157&southBL=29.4061&relation=overlaps®ion_simple=2&sortBy=relevance&sortOrder=&hitsPerPage=10&output=full
The problem is that the user, after using the <Enter> key for an Advanced
Search request, may have results, but cannot know that the request was in
Simple Search mode...
I found this in GN 2.6.4 but also in 2.9
Thanks, Victor
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1041>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
request.
Priority: major | Milestone: v2.8.0 RC1
Changes (by vsinceac):
* priority: minor => major
* milestone: v2.9.0 => v2.8.0 RC1
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1041#comment:1>
request.
Priority: major | Milestone: v2.8.0 RC2
Changes (by ianwallen):
* milestone: v2.8.0 RC1 => v2.8.0 RC2
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1041#comment:2>
request.
* milestone: v2.8.0 RC2 => v2.8.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1041#comment:3>
I have the same problem.
Tested with Geonetwork 2.8.0. (old GUI) on Jetty. My server and client
machine is the same: Windows 8 64bit. Tested with 3 browsers: Chrome
28.0.1500.72 m, Firefox 21.0 and IE10.
I see that it has been solved in Geonetwork 2.10 by not doing the search at
all when pressing the Enter key in advanced search. It would fit me also.
I tried to find out how it was done in 2.10, but could not find the fix.
I tried:
- comparing the diffs of 2.8 vs 2.10,
- searching the GN users&dev lists and trac
- and looking at the commit histories of most probable files where this fix
should hide itself:
- web/src/main/webapp/scripts/gn_search.js,
- web/src/main/webapp/xsl/main-page.xsl,
- web/src/main/webapp/xsl/searchform_advanced.xsl
It is hard to find since I probably do not know which file contains the
change I need. I also tried to search 'Ext.EventObject.ENTER' from every
project file since GN is using ExtJS and maybe this was the way it was done.
Can anyone help in finding this change in 2.10? Or recommend its own fix?
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-opensource-Developer-website-1041-Pressing-Enter-key-instead-Search-button-sends-only-Sim-tp5000720p5070026.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
I found that the enter key seems to be handled in
web/src/main/webapp/xsl/header.xsl, but the code is the same in 2.8 and
2.10.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-opensource-Developer-website-1041-Pressing-Enter-key-instead-Search-button-sends-only-Sim-tp5000720p5070036.html
Fixed the problem. Just changed how the cookie value is read in the JS code
that is in the web/src/main/webapp/xsl/header.xsl file.
Ill try to do a pull request in the near future.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-opensource-Developer-website-1041-Pressing-Enter-key-instead-Search-button-sends-only-Sim-tp5000720p5070052.html
request.
Type: defect | Status: closed
Resolution: fixed | Keywords: search button, enter key, simple search, advanced search
Changes (by kristjanr):
* status: new => closed
* resolution: => fixed
Comment:
https://github.com/geonetwork/core-geonetwork/pull/227
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1041#comment:4>
