[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1050: Add URI lookup entry to mcp 1.4 oasis-catalog.xml; typo error in mcp 1.4 oasis-catalog.xml
oasis-catalog.xml
Reporter: awalsh | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.8.0 RC0
Component: Metadata standards | Version: v2.8.0RC0
Keywords: schematron, codelist validation, oasis catalog |
Using latest GN2.8 the jeeves xmlresolver in conjunction with
the mcp-1.4 oasis-catlog.xml file is failing to resolve
this particular code list URI which is used extensively in existing
production MCP XML metadata:-
  <mcp:type>
      <mcp:DP_TypeCode
codeList="http://bluenet3.antcrc.utas.edu.au/mcp/resources/Codelist/gmxCodelists.xml#DP_TypeCode&quot;
codeListValue="longName" />
  </mcp:type>
DEBUG shows that this URI resolves to a non-existent web resource
i.e
2012-09-14 14:54:26,998 DEBUG [jeeves.xmlresolver] - Trying to resolve
http://bluenet3.antcrc.utas.edu.au/mcp/resources/Codelist/gmxCodelists.xml:file:/C:/ANZMEST_SVN9275/web/geonetwork
/WEB-INF/data/config/schema_plugins/iso19139.mcp-1.4/schematron-rules-iso-
codeListValidation.xsl
2012-09-14 14:54:26,998 DEBUG [jeeves.xmlresolver] - Resolved as
As a result the schematron process of codeList validation for
the mcp schema gmxCodelists.xml#DP_TypeCode was failing.
To fix this add the following to the mcp-1.4 oasis-catalog.xml file:
<uri
name="http://bluenet3.antcrc.utas.edu.au/mcp/resources/Codelist/gmxCodelists.xml&quot;
              uri="schema/resources/Codelist/gmxCodelists.xml"/>
Then the log shows this resolves OK to a local mcp codeList resource:
2012-09-14 15:40:43,061 DEBUG [jeeves.xmlresolver] - Trying to resolve
2012-09-14 15:40:43,061 DEBUG [jeeves.xmlresolver] - Resolved as
file:C:/ANZMEST_SVN9275/web/geonetwork/WEB-
INF/data/config/schema_plugins/iso19139.mcp-1.4/schema/resources/Codelist/gmxCodelists.xml
There looks like a small typo error in the mcp-1.4 oasis catalog file, an
umatched single
quote ' just before the "http" as follows:
<uri
name="'http://bluenet3.antcrc.utas.edu.au/mcp/schema/resources/Codelist/gmxCodelists.xml&quot;
  <uri
name="'http://bluenet3.antcrc.utas.edu.au/mcp-1.4/schema/resources/Codelist/gmxCodelists.xml&quot;
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1050&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
oasis-catalog.xml
Comment(by simonp):
Thanks Andrew - I have fixed this as part of #1043 - I'll close both when
I commit that after I get round to testing it.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1050#comment:1&gt;
oasis-catalog.xml
      Type: defect | Status: closed
Resolution: fixed | Keywords: schematron, codelist validation, oasis catalog
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in commit 4bd3d985c8d100c1db3318097882a5ce0905e38d
Note: changing the codelist URL from
to
http://bluenet3.antcrc.utas.edu.au/mcp-1.4/resources/Codelist/gmxCodelists.xml
takes place as part of the update-fixed-info.xsl (this is executed before
validation because the record is always saved before validating).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1050#comment:2&gt;
