[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1054: MCP cannot add gmd:LanguageCode via metadata editor
Reporter: ianwallen | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.8.0
Component: User interface (web) | Version: v2.8.0RC0
Keywords: |
Attempting to set the metadata language to an gmd:LanguageCode via the
metadata editor generates an empty pick list. It is not possible to add
the language via the interface.
OS: Windows XP
Using todays 2.8 nightly build and latest MCP schema plugin.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1054&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in commit:
https://github.com/geonetwork/schema-
plugins/commit/040570f4279ee292b0400424144fd9dd418cc5ff
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1054#comment:1&gt;
      Type: defect | Status: reopened
Resolution: | Keywords:
Changes (by ianwallen):
  * status: closed => reopened
  * resolution: fixed =>
Comment:
Simon,
The fix that you supplied seems to correct the issue. But I noticed
similar code...
Should the same fix be applied to the metadata-iso19139.mcp-edit.xsl as it
seems to have the same issue? I'm just not sure where it is used?
- <xsl:template mode="iso19139.mcp" match="*[*/@codeList and
name(.)!='gmd:country' and name()!='gmd:languageCode']">
+ <xsl:template mode="iso19139.mcp" match="*[*/@codeList and
name()!='gmd:country' and name()!='gmd:language']">
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1054#comment:2&gt;
  * status: reopened => closed
Comment:
metadata-iso19139.mcp-edit.xsl is used by the new widget editor - still
needs some checking out but yes the fix needs to be committed here too -
thanks.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1054#comment:3&gt;
