#1055: MCP - unable to add "Other language"
Reporter: ianwallen | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.8.0
Component: User interface (web) | Version: v2.8.0RC0
Keywords: |
When attempting to add "Other language" via the medatada editor, it always
sets the language to "English" so I'm unable to add other languages via
the interface.
OS: Windows XP
Using todays 2.8 nightly build and latest MCP schema plugin.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1055>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by ianwallen):
The problem seems to be in the update-fixed-info.xsl file.
<xsl:template match="gmd:languageCode[gmd:LanguageCode/@codeList]"
priority="10">
<xsl:copy>
<gmd:LanguageCode
codeList="http://www.isotc211.org/2005/resources/Codelist/ML_gmxCodelists.xml#LanguageCode"
codeListValue="eng">English</gmd:LanguageCode>
</xsl:copy>
</xsl:template>
Not sure why this was hard coded to "English"?
I also noticed the same for the Country - it is hard coded to "Australia"?
This means that code similar to the following would not be possible.
(Taken from [http://www.schemacentral.com/sc/niem21/e-gmd_PT_Locale.html\])
<gmd:PT_Locale>
<gmd:languageCode>
<gmd:LanguageCode codeList="http://www.example.com/"
codeListValue="http://www.example.com/">string</gmd:LanguageCode>
</gmd:languageCode>
<gmd:country>
<gmd:Country codeList="http://www.example.com/"
codeListValue="http://www.example.com/">string</gmd:Country>
</gmd:country>
<gmd:characterEncoding>
<gmd:MD_CharacterSetCode codeList="http://www.example.com/"
codeListValue="http://www.example.com/">string</gmd:MD\_CharacterSetCode>
</gmd:characterEncoding>
</gmd:PT_Locale>
I have upload a proposed patch based on the update-fixed-info.xsl from
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1055#comment:1>
Keywords: |
Comment(by simonp):
Fixed in commit:
https://github.com/geonetwork/schema-
plugins/commit/d4569f95a057c2a2a83678483b1b73e951ae2077
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1055#comment:2>
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by simonp):
* status: new => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1055#comment:3>
Type: defect | Status: reopened
Resolution: | Keywords:
Changes (by ianwallen):
* status: closed => reopened
* resolution: fixed =>
Comment:
I believe this was just a partial fix. It fixed the issue in that I can
now select another main languages for the MCP metadata.
However if I click on "Other Languages" for the metadata I get an blank
selection box. So I cannot create a multilingual record.
This may be related to Ticket #1054?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1055#comment:4>
* status: reopened => closed
Comment:
Yes - Both languageCode *and* language need to be processed in iso19139
mode to pick up the language select box - why can't we all speak one
language eg. esperanto? - would make things much easier! Thanks.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1055#comment:5>
