[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1062: Metadata info: version for update + id/uuid mapping.
Reporter: etj | Owner: geonetwork-devel@…
Priority: major | Milestone: v2.6.4
Component: Catalog server | Version: v2.6.4
Keywords: version id uuid update |
1) When updating metadata programmatically there is no easy way to get the
'''metadata version number''', used by geonetwork to avoid concurrent
updates.
2) There is no way to retrieve the '''internal id''' of a metadata, given
its uuid. This may be a problem if you need to perform a programmatic
update, and all you have is the uuid.
The attached patch provides two services:
== {{{xml.metadata.info.get}}} ==
A ''guest accessible'' service which takes as query param either "id" or
"uuid", and returns both:
e.g. 1
     http://localhost:8080/geonetwork/srv/it/xml.metadata.info.get?id=15
<response>
   <id>15</id>
   <uuid>49509107-abc4-4d0a-9b83-2aa27c9f1cb8</uuid>
</response>
e.g. 2
http://localhost:8080/geonetwork/srv/it/xml.metadata.info.get?uuid=49509107-abc4
<response>
   <id>15</id>
</response>
== {{{xml.metadata.info.getForUpdate}}} ==
An ''editor-accessible'' service similar to the above one, but that also
increments and return the internal metadata version number:
e.g. 3
http://localhost:8080/geonetwork/srv/it/xml.metadata.info.getForUpdate?id=15
<response>
   <id>15</id>
   <version>5</version>
</response>
e.g. 4
http://localhost:8080/geonetwork/srv/it/xml.metadata.info.getForUpdate?uuid=49509107-abc4
<response>
   <id>15</id>
   <version>6</version>
</response>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1062&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Comment(by fxp):
To get the internal id or uuid, you could use the search service:
  * for the UUID: http://localhost:8080/geonetwork/srv/eng/q?_uuid=c156fb97
-f3ea-4e61-b33f-b48236cb7f30
  * for the internal id: http://localhost:8080/geonetwork/srv/eng/q?_id=966
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1062#comment:1&gt;
Priority: major | Milestone: v2.6.5
Changes (by ianwallen):
  * milestone: v2.6.4 => v2.6.5
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1062#comment:2&gt;
