[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1064: cannot build Geonetwork using mvn
Reporter: plcking | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC0
Keywords: |
I cannot build the latest version of GN. Output from the build process
follows :
top - 12:17:42 up 356 days, 21:40, 2 users, load average: 0.09, 0.16,
0.07
Tasks: 27 total, 1 running, 26 sleeping, 0 stopped, 0 zombie
Cpu(s): 0.0%us, 0.0%sy, 0.0%ni,100.0%id, 0.0%wa, 0.0%hi, 0.0%si,
0.0%st
Mem: 3336192k total, 1896804k used, 1439388k free, 0k buffers
Swap: 0k total, 0k used, 0k free, 0k cached
   PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
     1 root 15 0 10368 744 624 S 0.0 0.0 0:00.20 init
  1386 root 18 0 11124 1456 628 S 0.0 0.0 0:25.31 syslog-ng
  1482 root 15 0 186m 110m 2428 S 0.0 3.4 267:45.51 puppetd
Script started on Wed 19 Sep 2012 12:15:00 PM EDT
apache@...889... > ./bld.sh;exit
+ Error stacktraces are turned on.
Apache Maven 2.2.1 (r801777; 2009-08-06 15:16:01-0400)
Java version: 1.6.0_27
Java home: /usr/java/jdk1.6.0_27/jre
Default locale: en_US, platform encoding: UTF-8
OS name: "linux" version: "2.6.18-274.el5.028stab093.2" arch: "amd64"
Family: "unix"
[DEBUG] Building Maven user-level plugin registry from: '/home/apache/.m2
/plugin-registry.xml'
[DEBUG] Building Maven global-level plugin registry from:
'/home/apache/mvn/apache-maven-2.2.1/conf/plugin-registry.xml'
[INFO] Scanning for projects...
[DEBUG] Adding managed dependencies for org.geonetwork-
opensource:geonetwork
[DEBUG] org.tuckey:urlrewritefilter:jar:3.2.0
[DEBUG] The following artifacts were filtered out for plugin:
org.codehaus.mojo:exec-maven-plugin:1.1 because they're already in the
core of Maven:
org.apache.maven:maven-project:jar:2.0.4:runtime
org.apache.maven:maven-model:jar:2.0.4:runtime
org.apache.maven:maven-artifact:jar:2.0.4:runtime
org.apache.maven:maven-artifact-manager:jar:2.0.4:runtime
org.apache.maven:maven-plugin-api:jar:2.0:runtime
org.codehaus.plexus:plexus-container-default:jar:1.0-alpha-9:runtime
These will use the artifact files already in the core ClassRealm instead,
to allow them to be included in PluginDescriptor.getArtifacts().
[DEBUG] Configuring mojo 'org.codehaus.mojo:exec-maven-plugin:1.1:exec'
[DEBUG] (f) basedir = /home/apache/geonetwork_source/geonetwork/web
[DEBUG] (f) classpathScope = compile
[DEBUG] (f) commandlineArgs = clean
[DEBUG] (f) environmentVariables = {ANT_OPTS=-client}
[DEBUG] (f) executable = ant
[DEBUG] (f) project = MavenProject: org.geonetwork-opensource
:geonetwork-main:2.9.0-SNAPSHOT @
/home/apache/geonetwork_source/geonetwork/web/pom.xml
[DEBUG] (f) skip = false
[DEBUG] (f) workingDirectory =
/home/apache/geonetwork_source/geonetwork/web/../schematrons
[DEBUG] -- end configuration --
[INFO] [exec:exec {execution: ant-schematrons-clean}]
[DEBUG] Args:
[DEBUG] <clean>
[DEBUG] parsed from <clean>
[DEBUG] executable ant not found in place, assuming it is in the PATH.
[INFO] Error occurred during initialization of VM
[INFO] Could not reserve enough space for object heap
[INFO] Could not create the Java virtual machine.
[INFO]
[ERROR] BUILD ERROR
[INFO]
[INFO] Result of /bin/sh -c cd
/home/apache/geonetwork_source/geonetwork/web/../schematrons && ant clean
execution is: '1'.
[INFO]
[DEBUG] Trace
org.apache.maven.lifecycle.LifecycleExecutionException: Result of /bin/sh
-c cd /home/apache/geonetwork_source/geonetwork/web/../schematrons && ant
clean execution is: '1'.
         at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:719)
         at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:556)
         at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:535)
         at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:387)
         at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:348)
         at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:180)
         at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:328)
         at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:138)
         at org.apache.maven.cli.MavenCli.main(MavenCli.java:362)
         at
org.apache.maven.cli.compat.CompatibleMain.main(CompatibleMain.java:60)
         at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
         at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
         at org.codehaus.classworlds.Laun
cher.launchEnhanced(Launcher.java:315)
         at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
         at
org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
         at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.MojoExecutionException: Result of
/bin/sh -c cd /home/apache/geonetwork_source/geonetwork/web/../schematrons
&& ant clean execution is: '1'.
         at org.codehaus.mojo.exec.ExecMojo.execute(ExecMojo.java:260)
         at
org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:490)
         at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:694)
         ... 17 more
[INFO]
[INFO] Total time: 48 seconds
[INFO] Finished at: Wed Sep 19 12:15:54 EDT 2012
[INFO] Final Memory: 80M/285M
[INFO]
apache@...889... >
apache@...889... >
apache@...889... >
apache@...889... > env | grep MAVEN_OPTS
MAVEN_OPTS=-Xmx512m -XX:MaxPermSize=128m -XX:MaxHeapSize=512m
apache@...889... >
apache@...889... >
apache@...889... > env | grep JAVA
JAVA_HOME=/usr/java/jdk1.6.0_27
apache@...889... >
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1064&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
