#1066: Schematron rules part of the schema plugin
Reporter: fxp | Owner: geonetwork-devel@…
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC0
Keywords: |
Main goal is to pack the schematron rules with the schema plugin in order
to easily add/update rules withtout the need of the source code.
Changes:
* move schematron rules for ISO 19139 to iso19139 schema plugin folder
* rules location
* {plugins}/schematron/*.sch : schematron rules
* {plugins}/schematron/*.xsl : compiled schematron rules
* {plugins}/loc/{lang}/schematron-*.xml : loc files
* move schematron XSL compiler to WEB-INF/classes/schematron
* remove schematron folder at root
* when schema is loaded,
* look for sch file in schema folder and compiles rules
* if no rules found, deal with no schematron rule on validation (ie. no
more schematron-rule-none.xsl)
Layout changes:
* some minor layout changes in the widget UI
[[Image(geonetwork-xsd-error.png)]]
To include iso19139 schematron rules in your plugins, add a simple XSL
which import the one needed:
* Example {myschema}/schematron/schematron-rules-iso.xsl
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
version="2.0">
<xsl:import href="../../iso19139/schematron/schematron-rules-
iso.xsl"/>
</xsl:stylesheet>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1066>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
