[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1073: CatalogSearcher closes index readers while they are still in use.
Reporter: jeichar | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC0
Keywords: |
I set up a jmeter test suite to stress test Geonetwork a little and I have
found some severe issues with the CSW support. I will try to explain the
issue:
User 1 makes CSW request
Catalog Searcher (using LuceneSearcher) begins processing request
User 2 makes CSW a different request
Catalog Searcher closes Index reader for last request and opens new reader
LuceneSearcher explodes because its index reader has been closed.
I think it is pretty clear what the problem is here but the solution is
not as simple we cannot leave requests open.
I propose making CatalogSearcher not cache index reader but instead open
each time it is needed.
CatalogSearcher will be stored on the UserSession so that the user is able
to select metadata using the searcher.
This simplifies the reader handling and reduces chances of resource leaks
in the CatalogSearcher.
See the patch at:
https://github.com/jesseeichar/core-
geonetwork/compare/master...bug;csw_getrecords_parallelism
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1073&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by jeichar):
  * status: new => closed
  * resolution: => fixed
Comment:
fix applied. commit id is: 0b7e345139ad5923f4a9006cd9ea8c67ae3314ba
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1073#comment:1&gt;
