#1081: Disclaimer form fails to appear when downloading local file as public user
Reporter: awalsh | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.8.0 RC2
Component: General | Version: v2.8.0RC0
Keywords: file.disclaimer, local file for download |
Using GN2.8RC1 clicking the 'Data for Download' button on the
'Physiographic Map of North and Central Eurasia (Sample record...'
and then selecting the 'local' file for download checkbox the
file.disclaimer
service (form) fails with a Java exception. The wheel just spins
and the disclaimer form never comes up.
The GN log:
2012-09-27 16:33:07,998 INFO [jeeves.request] - HTML Request (from
127.0.0.1) : /geonetwork/srv/eng/file.disclaimer
2012-09-27 16:33:07,998 DEBUG [jeeves.request] - Method : GET
2012-09-27 16:33:07,998 DEBUG [jeeves.request] - Content type : null
2012-09-27 16:33:07,998 DEBUG [jeeves.request] - Accept :
text/javascript, text/html, application/xml, text/xml, */*
2012-09-27 16:33:07,998 DEBUG [jeeves.request] - Session id is
1w8cjrggscchrcmh8gnms68h2
2012-09-27 16:33:07,998 INFO [jeeves.service] - Dispatching :
file.disclaimer
2012-09-27 16:33:08,029 DEBUG [jeeves.webapp.file.disclaimer] - Passed to
metadata-license-annex.xsl:
<root>
<metadata changedate="2007-11-06T12:10:47" currdate="2012-09-27
16:33:08">
<title>Physiographic Map of North and Central Eurasia (Sample record,
please remove!)</title>
2012-09-27 16:33:08,029 ERROR [jeeves.service] - Exception when executing
service
2012-09-27 16:33:08,029 ERROR [jeeves.service] - (C) Exc :
java.lang.NumberFormatException: null
2012-09-27 16:33:08,029 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
<message>null</message>
<class>NumberFormatException</class>
<stack>
<at class="java.lang.Integer" file="Integer.java" line="415"
method="parseInt" />
<at class="java.lang.Integer" file="Integer.java" line="497"
<at class="jeeves.server.UserSession" file="UserSession.java"
line="139" method="getUserIdAsInt" />
<at class="org.fao.geonet.services.feedback.AddLimitations"
file="AddLimitations.java" line="186" method="exec" />
<at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="230" method="execService" />
file="ServiceInfo.java" line="139" method="execServices" />
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="420" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="747" method="dispatch" />
</error>
2012-09-27 16:33:08,029 INFO [jeeves.service] - -> dispatching to
error for : file.disclaimer
2012-09-27 16:33:08,045 INFO [jeeves.service] - -> transforming with
stylesheet : C:\geonetwork2.8.0RC1\web\geonetwork\xsl/error.xsl
2012-09-27 16:33:08,514 INFO [jeeves.service] - -> end error
transformation for : file.disclaimer
2012-09-27 16:33:08,514 INFO [jeeves.service] - -> error ended for :
file.disclaimer
BTW everything is OK if you do this as the 'admin' user.
The Java stack trace above indicates some problem with:
FYI I uploaded this sample XML from the mef files provided
with the sample data in the iso19139 schema plugin.
Note: This ticket may be related to #1080
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1081>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
