[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1105: postgis query too large
Reporter: plcking | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.6.4
Keywords: |
The query that is being sent to postgres/postgis from geonetwork(as a
result of a csw spatial query) has over 50,000 "OR" clauses(the query
just "hangs") - here is the postgres log :
LOG: execute fetch from S_4/C_5: SELECT "fid", asText("the_geom") FROM
"public"."spatialindex" WHERE ("fid" = '10') OR ("fid" = '100') OR ("fid"
= '1000') OR ("fid" = '10001') OR ("fid" = '10005') OR ("fid" = '10011')
OR ("fid" = '10014') OR ("fid" = '10015') OR ("fid" = '10018') OR ("fid" =
'10020') OR ("fid" = '10021') OR ("fid" = '10023') OR ("fid" = '10025') OR
("fid" = '10027') OR ("fid" = '10032') OR ("fid" = '10038') OR ("fid" =
'10041') OR ("fid" = '10042') OR ("fid" = '10044') OR ("fid" = '10045') OR
("fid" = '10047') OR ("fid" = '10048') OR ("fid" = '1005') OR ("fid" =
'10050') OR ("fid" = '10051') OR ("fid" = '10052') OR ("fid" = '10053') OR
("fid" = '10054') OR ("fid" = '10055') OR ("fid" = '10058') OR ("fid" =
'10061') OR ("fid" = '10062') OR ("fid" = '10063') OR ("fid" = '10066') OR
("fid" = '10067') OR ("fid" = '1007') OR ("fid" = '10070') OR ("fid" =
'10076') OR ("fid" = '10080')........................
What can be done to fix the issue ?
Postgres seems to have a limit of 50,000 on the number of clauses(and this
makes sense from an efficiency standpoint) - I tested the query when there
were 49K clauses and it was successful.
Pat
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1105&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by jeichar):
Do you have a stack trace so I can see what series of calls are causing
this error?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1105#comment:1&gt;
Keywords: |
Comment(by plcking):
Replying to [comment:1 jeichar]:
this error?
The query jusy "hangs". Here is the output from geonetwork.log :
2012-10-09 10:55:58,036 INFO [jeeves.request] -
2012-10-09 10:55:58,036 INFO [jeeves.request] - HTML Request (from
132.156.10.107) : /geonetwork/srv/en/csw
2012-10-09 10:55:58,036 DEBUG [jeeves.request] - Method : POST
2012-10-09 10:55:58,036 DEBUG [jeeves.request] - Content type : text/xml
2012-10-09 10:55:58,036 DEBUG [jeeves.request] - Accept : */*
2012-10-09 10:55:58,036 DEBUG [jeeves.request] - Session id is
3BB6476D1ABB2409C67968E8F52F185D
2012-10-09 10:55:58,036 DEBUG [jeeves.request] - Session created for
client : 132.156.10.107
2012-10-09 10:55:58,038 INFO [jeeves.service] - Dispatching : csw
2012-10-09 10:55:58,038 DEBUG [jeeves.service] - -> parameters are :
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot;
xmlns:gml="http://www.opengis.net/gml
" service="CSW" version="2.0.2" resultType="results"
outputSchema="http://www.isotc211.org/2005/gmd&quot; maxRecords="100">
   <csw:Query typeNames="gmd:MD_Metadata">
     <csw:ElementSetName>full</csw:ElementSetName>
     <csw:Constraint version="1.1.0">
       <ogc:Filter>
         <ogc:Intersects>
           <ogc:PropertyName>BoundingBox</ogc:PropertyName>
           <gml:Envelope>
             <gml:lowerCorner>-44.00 -8.38</gml:lowerCorner>
             <gml:upperCorner>-40.00 1.00</gml:upperCorner>
           </gml:Envelope>
         </ogc:Intersects>
       </ogc:Filter>
     </csw:Constraint>
   </csw:Query>
</csw:GetRecords>
2012-10-09 10:55:58,039 INFO [jeeves.webapp.csw] - Received:
       <ogc:Filter>
         <ogc:Intersects>
           <gml:Envelope>
           </gml:Envelope>
         </ogc:Intersects>
       </ogc:Filter>
     </csw:Constraint>
   </csw:Query>
</csw:GetRecords>
2012-10-09 10:55:58,049 DEBUG [jeeves.engine] - TransformerFactoryFactory:
de.fzi.dbs.xml.transform.CachingTransformerFactory
2012-10-09 10:55:58,064 DEBUG [jeeves.engine] - TransformerFactoryFactory:
produces transformer implementation net.sf.saxon.IdentityTransform
er
Pat
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1105#comment:2&gt;
Keywords: |
Replying to [comment:2 plcking]:
causing this error?
> <ogc:Filter>
> <ogc:Intersects>
> <gml:Envelope>
> </gml:Envelope>
> </ogc:Intersects>
> </ogc:Filter>
> </csw:Constraint>
> </csw:Query>
> </csw:GetRecords>
> <ogc:Filter>
> <ogc:Intersects>
> <gml:Envelope>
> </gml:Envelope>
> </ogc:Intersects>
> </ogc:Filter>
> </csw:Constraint>
> </csw:Query>
> </csw:GetRecords>
TransformerFactoryFactory: produces transformer implementation
> er
> Pat
How does geonetwork construct the query ? Using so many feature Id's ?
Pat
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1105#comment:3&gt;
Keywords: |
My understanding of what is happening is the following:
The envelope query is converted to a lucene query which returns the ID of
all the metadata in question. Then the ids together form a database
query. Obviously some checks on the number of ids need to be added and
multiple queries will be made.
I would have expected the maxRecords to reduce the number of clauses.
Sounds like it is not taken into account at the right time.
Are you using version 2.6.4 as the bug report indicates?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1105#comment:4&gt;
Keywords: |
Replying to [comment:4 jeichar]:
of all the metadata in question. Then the ids together form a database
Hi :
First of all, I'd like to thank you for your help so far. I really
appreciate it !
The number of records that I have imported is in excess of 400,000. I
never had the problem when the db had 330,000 records.
I am definitely using geonetwork v2.6.4.
Pat
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1105#comment:5&gt;
We did come across this as well in building catalogs with a couple of million records. A work around is to increase the operating system stack size resources and max_stack_depth in postgis config as explained in the section of the users manual on advanced configuration. The section of the manual that explains how to do this is available online at:
http://geonetwork-opensource.org/manuals/trunk/eng/users/admin/advanced-configuration/index.html#advanced-configuration-for-larger-catalogs
Simon
________________________________________
From: GeoNetwork opensource Developer website [trac_osgeo@anonymised.com]
Sent: Wednesday, 10 October 2012 5:26 AM
Subject: Re: [GeoNetwork-devel] [GeoNetwork opensource Developer website] #1105: postgis query too large
Keywords: |
Hi :
appreciate it !
Pat
Ticket URL: <#1105 (postgis query too large) – GeoNetwork opensource Developer website;
Don't let slow site performance ruin your business. Deploy New Relic APM
Deploy New Relic app performance management and know exactly
what is happening inside your Ruby, Python, PHP, Java, and .NET app
Try New Relic at no cost today and get our sweet Data Nerd shirt too!
Best Open Source Mac Front-Ends 2024
GeoNetwork-devel mailing list
geonetwork-devel List Signup and Options
How large should I set BooleanQuery.setMaxClauseCount to be?
Jesse
On Wed, Oct 10, 2012 at 2:16 PM, GeoNetwork opensource Developer website <trac_osgeo@anonymised.com> wrote:
Reporter: plcking | Owner: jeichar
Type: defect | Status: reopened
Resolution: | Keywords:
Replying to [comment:13 jeichar]:
If I make a new war for you can you test it to see if my fix works for
you?
Thank you for your help !!!
I think a war file would help, and I will re-edit(after tomcat war
expansion) the ./web/geonetwork/WEB-INF/config.xml to point to my postgis
db. Of special note is that I had to modify(when I had 300k records)
./WEB_INF/classes/org/fao/geonet/kernel/search/LuceneSearcher.java
(BooleanQuery.setMaxClauseCount had to be set to a large value due to a
“too many clauses” error). If you don’t include the change for this, I
have my CLASSPATH env var set to recompile the code “tomcat in-situ” (I
couldn’t build the distribution with maven due to numerous errors).
Pat
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1105#comment:14>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
