[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1110: Language listing should be ordered
Reporter: ianwallen | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: minor | Milestone: v2.8.0
Component: User interface (web) | Version: v2.8.0RC1
Keywords: |
The language drop-down list does not seem to be sorted in any particular
order. Since the list is getting longer it should probably be sorted
correctly.
The current list is as follows
   ||ara ||عربي ||
   ||cat ||Català ||
   ||chi ||中文 ||
   ||ger ||Deutsch ||
   ||eng ||English ||
   ||spa ||Español ||
   ||fre ||Français ||
   ||ita ||Italiano ||
   ||dut ||Nederlands||
   ||nor ||Norsk ||
   ||por ||Рortuguês ||
   ||rus ||Русский ||
Should this be sorted manually or via JavaScript code?
  * If manually then what should be the order. i.e. Do Arabic characters
come before "a" or after "z"?
  * JavaScript may require a little fiddling as some of the characters are
UTF-8 and may not get displayed in the desired order i.e. Р in Русский
comes before C in Català if using JavaScript sort function.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1110&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by ianwallen):
According to Oracle
http://docs.oracle.com/cd/B12037_01/server.101/b10749/ch5lings.htm
section Linguistic Indexes for Multiple Languages
...Build a single linguistic index for all languages using one of the
multilingual linguistic sorts such as GENERIC_M or FRENCH_M. These indexes
sort characters according to the rules defined in ISO 14651. ...
So assuming that we want to follow ISO 14651
I believe this is how we should be sorting the languages.
select nls_upper(name, 'NLS_SORT=GENERIC_M') from languages order by
NLSSORT(nls_upper(name, 'NLS_SORT=GENERIC_M'), 'NLS_SORT=GENERIC_M');
NLS_UPPER(NAME,'NLS_SORT=GENERIC_M')
CATALÀ
DEUTSCH
ENGLISH
ESPAÑOL
FRANÇAIS
ITALIANO
NEDERLANDS
NORSK
POLSKI
PORTUGUÊS
SUOMI
TIẾNG VIỆT
TÜRKÇE
РУССКИЙ ЯЗЫК
العربية
中文
If there are no objections I will proceed with making the changes.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1110#comment:1&gt;
