#1127: recommendations on optimizing lucene indexes needed
Reporter: plcking | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.6.4
Keywords: |
I have 400K records (ISO19115) loaded into Geonetwork. I have implemented
all the recommendations in http://geonetwork-
opensource.org/manuals/trunk/users/admin/advanced-
configuration/index.html. I am finding that the following CSW
search(below) is taking longer than 60 seconds at times. I am assuming
that optimizing the lucene indexes will help, but I am worried about the
amount of time that optimizing will consume. Should I used
lukeall-1.0.1.jar OR is there a way to call a servlet directly (say, using
wget) to invoke the optimization ? Can I make CSW calls with a reasonable
response time during the optimization ?
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
service="CSW" version="2.0.2" resultType="hits"
outputSchema="http://www.iso
tc211.org/2005/gmd" maxRecords="10">
<csw:Query typeNames="dataset,application,datasetcollection,service">
<csw:ElementSetName>summary</csw:ElementSetName>
<csw:Constraint version="1.1.0">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml">
<ogc:And>
<ogc:PropertyIsLike wildCard="*" singleChar="#" escapeChar="\">
<ogc:PropertyName>dc:title</ogc:PropertyName>
<ogc:Literal>%Radarsat-2%</ogc:Literal>
</ogc:PropertyIsLike>
<ogc:PropertyIsGreaterThanOrEqualTo>
<ogc:PropertyName>TempExtent_begin</ogc:PropertyName>
<ogc:Literal>2012-10-01t00:00:00Z</ogc:Literal>
</ogc:PropertyIsGreaterThanOrEqualTo>
<ogc:PropertyIsLessThanOrEqualTo>
<ogc:PropertyName>TempExtent_end</ogc:PropertyName>
<ogc:Literal>2012-10-31t07:30:00Z</ogc:Literal>
</ogc:PropertyIsLessThanOrEqualTo>
</ogc:And>
</ogc:Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1127>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by heikki):
I would be careful assuming that optimizing will help at all, rather than
make things worse (see http://www.searchworkings.org/blog/-/blogs/simon-
says%3A-optimize-is-bad-for-you).
Maybe we should consider moving to Lucene 4.0 (see e.g.
http://blog.thetaphi.de/2012/02/is-your-indexreader-atomic-major.html).
It may also be helpful if you use an analyzer like !YourKit first, to
determine if your slowness really comes from Lucene.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1127#comment:1>
Keywords: |
Comment(by fxp):
I agree with Heikki, you should first check were is your slowness. Also
using the same approach as in
http://trac.osgeo.org/geonetwork/wiki/proposals/LuceneOnlySearch to CSW
service could probably help (but maybe not that easy if you need ISO19139
as output).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1127#comment:2>
Keywords: |
Comment(by plcking):
Replying to [comment:2 fxp]:
as output).
I'm in the process of installing YourKit now....Pat
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1127#comment:3>
Keywords: |
It looks like Lucene indexing search routines are the culprit.
I'm assuming that you have YourKit installed, so I would like to send you
cpu and memory snapshots of the query. I can't upload the snapshots to
this site due to file size(> 4Mb.), so do you have an alternative ?
Pat
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1127#comment:4>
Keywords: |
Comment(by jesseeichar):
Do you have a ftp server we can download them from?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1127#comment:5>
Keywords: |
Replying to [comment:5 jesseeichar]:
Please try the following URL's :
http://ceocat.ccrs.nrcan.gc.ca/memory.snapshot
http://ceocat.ccrs.nrcan.gc.ca/cpu.snapshot
Pat
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1127#comment:6>
Keywords: |
I have downloaded them. But I am really busy right now so I am not
completely sure when I will have time to analyze them. Perhaps you can
get the queries and run then with luke and see if what can be done to
speed them up?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1127#comment:7>
