[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1130: Schema plugins can cause startup failure
Reporter: heikki | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: minor | Milestone: v2.8.0
Component: General | Version: v2.8.0RC2
Keywords: |
If you have a sub directory in <data-dir>/config/schema_plugins that is
empty (or, does not contain a file named schema-ident.xml), GeoNetwork
fails to startup.
Now it may be so that there /should/ not be such empty directories in that
location, but still the Schema Plugin implementation could be more lenient
and just ignore such directories rather than to cause startup failure.
This problem is bigger, for developers, now we use Git, which does not
delete directories where it should, if you change between branches.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1130&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in commit a961fb988d63d64f4e3a51ad50607b6290e2c6dd
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1130#comment:1&gt;
