#1136: Batch import message misleading
Reporter: ianwallen | Owner: geonetwork-devel@…
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC2
Keywords: |
If uploading one MEF2 file using the batch import tool, the message
displayed is not correct.
Assuming everything is OK you will get the message
Total number of metadata records processed: 1
Total number of metadata records added: 1
0 errors
But this is the total number of files process. Since the MEF file may
hundreds of records, this is not the total number or metadata records
process.
A better message would be something like the following
Total number of file processed: 1
Total number of metadata records processed: 100
Total number of metadata records added: 100
0 errors
Since we are more interested in the real number of metadata records that
were add/modified and not the number of files processed.
Also if there is an error in one of the files, it would be nice to
identify the file with the error. I.e. If I batch upload 3 MEF files with
errors I get the following.
Total number of file processed: 3
Total number of metadata records processed: 3
Total number of metadata records added: 0
3 errors
import-file1.mef: No valid metadata file found in xxxxxxxx-xxxx-xxxx-
xxxx-xxxxxxxxxxxxx/metadata/.
import-file2.mef: No valid metadata file found in yyyyyyyy-yyyy-yyyy-
yyyy-yyyyyyyyyyyyy/metadata/.
import-file3.mef: No valid metadata file found in zzzzzzzz-zzzz-zzzz-
zzzz-zzzzzzzzzzzzz/metadata/.
3 errors
No valid metadata file found in xxxxxxxx-xxxx-xxxx-xxxx-
No valid metadata file found in yyyyyyyy-yyyy-yyyy-yyyy-
No valid metadata file found in zzzzzzzz-zzzz-zzzz-zzzz-
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1136>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
