#1140: Missing online resource protocols
Reporter: ianwallen | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.8.0
Component: General | Version: v2.8.0RC2
Keywords: |
It seems like the code is currently hard coded to used the following
protocols however they are not in the protocol list
([https://github.com/geonetwork/core-
geonetwork/blob/master/web/src/main/webapp/loc/eng/xml/strings.xml#L712])
||WWW:LINK-*http--download || iso-19139 ||
||WWW:LINK-1.0-http--metadata-URL || MCP ||
||WWW:LINK-*http--downloaddata || MCP ||
These should be added to the list otherwise what is happening, is that
they assigned but when the protocol drop down list is shown - it ends up
defaulting to the first item in the list.
See the following thread
[http://osgeo-org.1560.n6.nabble.com/Questions-regarding-online-resource-
protocols-inconsistencies-tc5013538.html]
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1140>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by ianwallen):
If someone wants to supply me with the protocol values and the associated
text then I can add them to the list.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1140#comment:1>
Keywords: |
I believe I found the value to be used.
<protocolChoice value="WWW:LINK-1.0-http--download">Web address for
download</protocolChoice>
comes from
[https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/sandbox/geocat.ch/trunk/web/geonetwork/loc/eng/xml\]
<protocolChoice show="y" value="WWW:LINK-1.0-http--metadata-URL">Metadata
URL</protocolChoice>
<protocolChoice show="y" value="WWW:LINK-1.0-http--downloaddata">Data for
download (URL)</protocolChoice>
Comes from
[https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/sandbox/BlueNetMEST/ANZMEST/web/src/main/webapp
/WEB-INF/anzmest-config-overrides.xml]
As the MCP file are added based on the anzmest-config-overrides.xml - it
seems that if these are added to the current list, it may cause some
issues.
Any objection with adding these to the current list?
The reason I believe they should be there is because they are hard coded
in the current logic and if they are not added the protocol drop down list
defaults to to first item in the list.
If there are objections it is not a problem - a work around would be to
create my own config-overrride to include these value.
Any comments?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1140#comment:2>
Keywords: |
Note: This is related to Ticket #984
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1140#comment:3>
Type: defect | Status: closed
Resolution: invalid | Keywords:
Changes (by ianwallen):
* status: new => closed
* resolution: => invalid
Comment:
I now have a better understanding of this list and it seems to be related
to not being able to fully separate the xsl from other projects such as
anzmest and geocat.
Ticket #984 should help separate the projects better.
So Marking it as invalid for now.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1140#comment:4>
