[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1159: File upload menu in modalbox will only appear once
Reporter: simonp | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC2
Keywords: |
If you add an online resource, choose file for download as protocol, and
click on upload file then modal box will appear and file upload can be
done.
However if you add another online resource and choose file for download as
protocol, click on upload file then modal box will no longer appear.
Service is called to prepare modalbox form for file upload but modalbox
won't show.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1159&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Priority: major | Milestone: v2.8.0
Keywords: |
Changes (by ianwallen):
  * milestone: v2.9.0 => v2.8.0
Comment:
The bug seems to be related to the auto closing of the popup windows. From
the test that I have done - after the file has been uploaded there is a
quick status report on the file size and filename uploaded. If I close
this popup manually before it does the auto close then the next file
upload will work correctly. If I let it timeout and close itself then the
next one will not work.
Note: this is not related to adding a new protocol. If editing an existing
metadata record containing several options to upload a file the same bug
occurs.
I quickly looked at the code and could not easily locate where the auto
close code was located.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1159#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Move editor form save into afterHide event on modal box that shows file
upload results - otherwise modalbox gets treated badly by editor form save
and won't come back to life again
Fixed in commit 4ddc647d2c06919285422f8932c03bdcc68f2fab
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1159#comment:2&gt;
