#1161: Running on IBM Java
Reporter: mcr | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.8.0
Component: General | Version: v2.8.0RC2
Keywords: |
Geonetwork uses Spring 2.5.3 which does not work with an IBM java 6
runtime. I tested with Spring 2.5.5 (modifying the pom.xml) and the error
disappeared.
Is it possible to use 2.5.5 generally. We are running geonetwork on
pSeries machines and the only available java is from IBM.
Intel Platforms running Linux and IBM Java have the same problem.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1161>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by jesseeichar):
trunk version uses 3.1+ version of spring. but I imagine it should be ok
to upgrade 2.8 to use spring 2.5.5
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1161#comment:1>
Keywords: |
Comment(by mcr):
This would be nice. I think a patch from my side is an overkill, I only
replaced one digit in the version number ( pom.xml) to get things working.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1161#comment:2>
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by jesseeichar):
* status: new => closed
* resolution: => fixed
Comment:
Fix applied to 2.8 branch : c91d0b25a5bec59450261f68c79a4e0bee7470cb
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1161#comment:3>
