#1169: GeoNetwork+PostGIS requires gt_pk_metadata (primary key metadata) because
query to get metadata db fails
Reporter: simonp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC2
Keywords: |
Ever more complex: this is all to do with geotools deciding whether the
spatialindex table is writable or not (ie. can it be used as a feature
store as opposed to a read only feature source). If geotools decides that
spatialindex is not writable then everything fails as a read only feature
source is useless to GeoNetwork. One of the tests to determine whether
spatialindex is writable is identifying its primary keys.
Turns out that the gt_pk_metadata table we've been discussing is the first
choice for geotools in identifying primary keys of spatialindex ie. if it
exists then it is used. If it doesn't exist then geotools uses
java.sql.Database to get info (including primary keys) from the database.
For postgres/postgis it seems that the query to get the primary keys
actually fails! What this means is that we have to have the gt_pk_metadata
table present, otherwise geotools can't identify the primary keys and will
decide that spatialindex is not writable causing GeoNetwork to fail.
Hmm. Ok - I've rigged up a fix for the create-db-postgis.sql file that
creates gt_pk_metadata and populates it correctly (taking into account it
might already exist etc). However I'll try a few other paths to see
whether we can do this the normal/proper way before suggesting we apply
this fix (already tried lots of jdbc driver versions - which didn't help)
as we shouldn't need to build/maintain the gt_pk_metadata table.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1169>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by simonp):
Seems likely that this is a problem is caused by order of search for
primary keys in postgis datastore, which is: first check is a query for
gt_pk_metadata (MetadataTablePrimaryKeyFinder) and second check is a query
for the database metadata (HeuristicPrimaryKeyFinder) - seems that the
first check for gt_pk_metadata aborts the transaction if that table
doesn't exist so the second check for database metadata does not return
any results. Proved by disabling the first check in geotools - this allows
the second check to succeed and GeoNetwork is happy.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1169#comment:1>
Keywords: |
Comment(by simonp):
This appears to be a bug in geotools (hate to say this as geotools is
excellent). Is present in 8.2 and in 8.4 (the latest). Easiest fix for
GeoNetwork 2.8.x and later is to create an empty gt_pk_metadata table (if
not already present) so that the first metadata primary key check does not
abort the transaction and the second metadata primary key check can
succeed. This will be a change to the create-db-postgis.sql file only.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1169#comment:2>
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by simonp):
* status: new => closed
* resolution: => fixed
Comment:
Fixed in commit ea018d2ed8561aba285d136ab9a4c4b2aa385dfd
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1169#comment:3>
Priority: major | Milestone: v2.8.0
Changes (by ianwallen):
* milestone: v2.9.0 => v2.8.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1169#comment:4>
