#1172: xml.user.login needs to be implemented again
Reporter: mfeil | Owner: geonetwork-devel@…
Type: task | Status: new
Priority: blocker | Milestone: v2.9.0
Component: Catalog server | Version:
Keywords: Security, Webservice, Login, Spring, Import |
Greetings,
2.9.0-SNAPSHOT looking good so far, but its a major rebound not having the
xml.user.login service for transaction requests. There are many Geonetwork
setups in service oriented infrastructures, wich rely on the posibility to
insert vast amount of metadata via webservice requests, wich now cant
operate.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1172>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Component: General | Version:
Changes (by mfeil):
* component: Catalog server => General
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1172#comment:1>
I found this to be an issue as well with the current GeoNetwork 2.8.0 RC2.
View this message in context: http://osgeo-org.1560.n6.nabble.com/GeoNetwork-opensource-Developer-website-1172-xml-user-login-needs-to-be-implemented-again-tp5019821p5020108.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Geonetwork 2.8 shouldn’t have the new security so I don’t know why it would have this issue.
On Sat, Dec 1, 2012 at 9:59 PM, ByronCinNZ <cochranes4@anonymised.com51…> wrote:
Keep yourself connected to Go Parallel:
INSIGHTS What’s next for parallel hardware, programming and related areas?
Interviews and blogs by thought leaders keep you ahead of the curve.
http://goparallel.sourceforge.net
GeoNetwork-devel mailing list
