[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1179: StringIndexOutOfBounds exception in LuceneQueryBuilder#addLocaleTerm when requestedLanguageOnly value is 'false'
Reporter: simonp | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: blocker | Milestone: v2.9.0
Component: General | Version: v2.8.0RC2
Keywords: |
Reported by brian.ohare@...96...:
I'm getting StringIndexOutOfBounds exception in
'false'. Not sure if I've configured the database settings correctly as
code seems to check for prefix 'only_' or 'prefer'. Exception occurs in
'prefer' check, so perhaps should be more stringent checking there? This
breaks search for me on 2.8.x RC2.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1179&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by simonp):
Brian,
Is this on the latest build of RC2? I committed a patch that changed some
of this logic yesterday (Dec 11). I'll check it out in the latest build
shortly.
Simon
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1179#comment:1&gt;
Keywords: |
Comment(by simonp):
....and so there is no confusion here - the author of the patch was Jesse
Eichar (I backported it to 2.8.x RC2) - so feel free to step in Jesse....
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1179#comment:2&gt;
Keywords: |
Comment(by simonp):
Can't reproduce it in the latest RC2 built - checked all the options and
they seem to work as I would expect (at least I can see the locale query
and language detection stuff doing what I would expect for each option).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1179#comment:3&gt;
Keywords: |
Comment(by bjohare):
Hi Simon,
Yes its the latest build of RC2. It's not against a clean install of the
database though which may be the issue. Is there some sql I can to run to
update the multilingual settings?
cheers,
Brian.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1179#comment:4&gt;
Keywords: |
Comment(by jesseeichar):
The migration scripts should contain the sql you need. Take a look at
them.
The migration task only runs if the previous version is 2.6 or earlier so
they probably didn't run automatically for you. Take a look at them and
manually execute the needed sql.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1179#comment:5&gt;
Keywords: |
Thanks Jesse will try that.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1179#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1179#comment:7&gt;
