#1200: Converter icons in metadata results are not displayed (only 2.9.x)
Reporter: josegar74 | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version:
Keywords: |
This is related to spring security changes, seem this code in metadata-
utils.xsl:
<xsl:for-each
select="/root/gui/schemalist/name[text()=$schema]/conversions/converter">
<xsl:variable name="serviceName" select="@name"/>
<xsl:if test="java:isAccessibleService($serviceName)">
sends a node tree object to isAccessibleService instead of the string
value with service name.
Changing serviceName variable to:
<xsl:variable name="serviceName" select="concat('',@name)"/>
solves the issue
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1200>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by josegar74):
* status: new => closed
* resolution: => fixed
Comment:
Committed in master: 9ee495ff5c97b4f083dd47e101b5395e4eef0008
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1200#comment:1>
Component: General | Version: v2.9.0
Changes (by ianwallen):
* version: => v2.9.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1200#comment:2>
