#1203: Widget - Customised OtherAction menu and Metadata menu
Reporter: fgravin | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC2
Keywords: |
Give possibility to add customised actions in otherAction menu
(MetadataResultsToolbar) and MetadataMenu (MetadataResultsView).
* otherActionMenu
Pass customOtherActions attribute to the GeoNetwork.MetadataResultsToolbar
as a Menu.Item type (array of actions, action, etc..)
Exemple :
var extractAction = new Ext.Action({
text: 'Extract Data',
handler: extractMetadata
var visuAction = new Ext.Action({
text: 'Visualize data',
tBar = new GeoNetwork.MetadataResultsToolbar({
catalogue: catalogue,
searchFormCmp: Ext.getCmp('searchForm'),
sortByCmp: Ext.getCmp('E_sortBy'),
metadataResultsView: metadataResultsView,
permalinkProvider: permalinkProvider,
customOtherActions: [extractAction,visuAction]
* MetadataMenu
* Add custom Action
Pass addCustomAction parameter as a function to the
GeoNetwork.MetadataResultsView. This function will be called on
MetadataMenu init method.
Exemple :
addCustomAction: function() {
var id = this.record.get('id');
handler: function() {
extractMetadata(id);
this.insert(0,visuAction);
this.insert(0,extractAction);
* Completly change configuration
If you want to completly change the MetadaMenu configuration (remove
component, change order, add submenus etc..), you can override
composeMenu() method of GeoNetwork.MetadataMenu
this.contextMenu = new GeoNetwork.MetadataMenu({
floating: true,
record: record,
resultsView: dv,
composeMenu: function(){
this.add(this.editAction);
this.add(this.deleteAction);
this.add(this.duplicateAction);
this.add(this.adminAction);
this.add(this.categoryAction);
this.add(this.createChildAction);
this.add(this.statusAction);
this.add(this.versioningAction);
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1203>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
