#1205: Schema configuration / Add support for read/write UUID
Reporter: fxp | Owner: geonetwork-devel@…
Priority: minor | Milestone: v2.9.0
Component: General | Version: v2.9.0
Keywords: |
Some ISO Profile defines rules to compute metadata UUID (eg. based on
resource identifier - made in UFO) which requires the UUID stored in the
column uuid of the metadata table to be in synch with the XML document.
Currently, the metadata uuid is only updated when the record is inserted
or harvested.
In schema-ident.xsl, add an optional parameter:
</autodetect>
<!-- After edits, db UUID is synchronized with the record.
If not, db UUID is only set when inserting the record or
harvested. -->
<readwriteUuid>true</readwriteUuid>
</schema>
If readwriteUuid is set to true, then when updating a metadata, the uuid
from the XML document updates the one in the metadata table.
Default is false.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1205>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
