#1210: Csw constraint parsing fails to parse expressions numeric with numeric
fields
Reporter: jesseeichar | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC2
Keywords: |
fields like: northBL the constructed object is not a Numeric Range object
and thus fails to correctly search for those elements.
A possible fix is to use the StandardQueryParser which appears to be a
more flexible parser and specify the numeric fields using the
LuceneConfig.
See https://github.com/geonetwork/core-
geonetwork/commit/2a271f41be18a1d104e0137f0ce2e68300d02c26
for the patch
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1210>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
fields
Keywords: |
Comment(by jesseeichar):
A bug fix is in this commit as well: https://github.com/geonetwork/core-
geonetwork/commit/6da4efd45ffeb5c250712e23bdb39f32b3a0250e
The new parser does not always create BooleanQueries so this check is
needed.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1210#comment:1>
fields
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by jesseeichar):
* status: new => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1210#comment:2>
