#1221: Can't edit the permissions on all the metadata at once
Reporter: agueganno | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.8.0
Component: General | Version: v2.8.0RC2
Keywords: postgresql database |
We're using geonetwork version 2.8.0, last RC built from github sources.
We're based on f84cb00a0ffd5c59df2ab9996b4835250e6db9ab.
Description of the problem :
We are using the new UI rather than the "legacy" one.
We connect as an administrator. We select all the metadata records and do
"Other Actions" -> "Update Privileges". We then edit the permissions,
validate them... and nothing seems to be happening. If coming back to the
metadata records, we can't see them anymore : even while being an
administrator, we can't select a metadata record and view its content.
Reproducible : Yes, happens anytime we follow this procedure.
Additional information :
We are using PostgreSQL here rather than the default embedded H2. When
sending our request through the web UI, we can see a new query running in
the postgresql database cluster :
SELECT metadataId FROM OperationAllowed WHERE metadataId=$1 AND groupId=$2
AND operationId=$3
It does not seem to be able to end this query. I find the query itself
dubious, but I'm absolutely not a DB specialist. You'll probably be better
judges
I've not been able to test with other DBs - I just don't have the time for
that currently :-(. Consequently, I'm not able to say if it's postgresql
specific or not. I haven't look much in geonetwork/jeeves code bases
either.
From the log, I can't see much things... under certain conditions, I can
find a "Operation not allowed" error message, but not while logged as an
admin. The error is pasted in the end of the ticket.
If I select only the metadata records that are in the current page, I can
perform the edition without any problem. The bug seems to happen only when
I select all the records.
That's all I can say for now. If you need any other information, ask and
I'll try to provide them as soon as possible.
Best wishes,
Alexis.
<error id="operation-not-allowed">^M
<message>Operation not allowed</message>^M
<class>OperationNotAllowedEx</class>^M
<stack>^M
<at class="org.fao.geonet.lib.ResourceLib" file="ResourceLib.java"
line="131" method="checkPrivilege" />^M
<at class="org.fao.geonet.services.metadata.View" file="View.java"
line="93" method="exec" />^M
<at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="230" method="execService" />^M
file="ServiceInfo.java" line="139" method="execServices" />^M
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="420" method="dispatch" />^M
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="747" method="dispatch" />^M
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="208" method="execute" />^M
file="JeevesServlet.java" line="109" method="doGet" />^M
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="621" method="service" />^M
line="722" method="service" />^M
<skip>...</skip>^M
<at class="org.fao.geonet.monitor.webapp.WebappMetricsFilter"
file="WebappMetricsFilter.java" line="96" method="doFilter" />^M
<skip>...</skip>^M
<at
class="org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter"
file="MetricsRegistryInitializerFilter.java" line="31" method="doFilter"
/>^M
<skip>...</skip>^M
</stack>^M
<request>^M
<language>fre</language>^M
<service>view</service>^M
</request>^M
</error>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1221>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
