#1222: Editor / Wiki formatting / Configure per schema
Reporter: fxp | Owner: geonetwork-devel@…
Priority: minor | Milestone: v2.9.0
Component: General | Version: v2.9.0
Keywords: |
Add mechanism to configure field with wiki syntax per schema.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1222>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by fxp):
Proposal:
* use saxon:call template using schema identifier in template name in
layout.xsl
<saxon:call-template name="{concat('permitMarkup-',$schema)}"/>
* add mode for configuration in <schema>/present/metadata-markup.xsl
<xsl:template name="permitMarkup-iso19139">
<xsl:apply-templates mode="permitMarkup-iso19139"
select="."/>
</xsl:template>
<xsl:template mode="permitMarkup-iso19139"
match="gmd:abstract | gmd:description | gmd:statement |
gmd:purpose | gmd:supplementalInformation">
<xsl:value-of select="true()"/>
</xsl:template>
<xsl:template mode="permitMarkup-iso19139" match="*">
<xsl:value-of select="false()"/>
</xsl:template>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1222#comment:1>
