[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1228: xml.metadata.status.values.list was replaced by xml.info?type=status / search by status broken
Reporter: landry | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC2
Keywords: |
In 7caf977c2a3 xml.metadata.status.values.list was added as the url to
call to populate data.StatusStore. That service was moved to
xml.info?type=status in 474437d, but Catalogue.js still refers to
xml.metadata.status.values.list, leading to errors in the log :
2013-02-21 09:04:34,388 ERROR [jeeves.service] - Service not found :
2013-02-21 09:04:34,389 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="service-not-found">
   <message>Service not found</message>
   <class>ServiceNotFoundEx</class>
   <object>xml.metadata.status.values.list</object>
   <request>
     <language>fre</language>
     <service>xml.metadata.status.values.list</service>
   </request>
</error>
a simple fix would be the following :
diff --git a/web-
client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/Catalogue.js b
/web-client/src/main/resources/apps/js/GeoNetwor
index bfd3ea4..9e43337 100644
--- a/web-
+++ b/web-
@@ -351,7 +351,7 @@ GeoNetwork.Catalogue = Ext.extend(Ext.util.Observable,
              xmlError: serviceUrl + 'xml.main.error',
              searchKeyword: serviceUrl + 'xml.search.keywords',
              getThesaurus: serviceUrl + 'xml.thesaurus.getList',
- getStatus: serviceUrl + 'xml.metadata.status.values.list',
+ getStatus: serviceUrl + 'xml.info?type=status',
              getKeyword: serviceUrl + 'xml.keyword.get',
              searchCRS: serviceUrl + 'crs.search',
              getCRSTypes: serviceUrl + 'crs.types',
but even with that, when logged as admin the StatusStore stays empty after
store.load() in SearchFormTools.js:getStatusField() - so there might be
another issue there. Using firebug, getLabel() in StatusStore is not even
called.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1228&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by landry):
changing record: 'record' to record: 'status' in data/StatusStore.js at
least allows the store to be populated with labels, since the returned xml
contains <status> items - not <record> items. Yet, the search by status
doesnt work, and i suspect because it cant find the id which is an xml
property of <status> and not a full-fledged xml child element.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1228#comment:1&gt;
Keywords: |
Comment(by landry):
I looked at CategoryStore.js and finally found out that mapping had to be
set for id field for it to work - with that patch, i can search by status
as admin and the records are properly returned
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1228#comment:2&gt;
      Type: defect | Status: closed
  Priority: major | Milestone: v2.8.1
Resolution: fixed | Keywords:
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
  * milestone: v2.9.0 => v2.8.1
Comment:
Fixed in commits 294a922b6db13a6a8d6ec1fffd2a9b91038c4d85 and
694675febd99cd4238a3d0422b38548698bf71c0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1228#comment:3&gt;
