#1229: Geopublish button inactive if md title contains a crlf
Reporter: landry | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC2
Keywords: |
I have a metadata which title contains a crlf, ie
Espaces Naturels Sensibles -
Département du Cantal - 2013
This makes the Geopublish button inactive in the widgets edit view, and
the console prints a message such as
Timestamp: 02/26/13 16:50:45
Error: SyntaxError: unterminated string literal
Source File: http://ids-dev.craig.fr/geocat/apps/search/index_debug.html
Line: 1, Column: 60
Source Code:
', 'a6a5a793-b9d1-4351-974a-fffd20644614', 'Espaces
I suppose this is because the xsl in iso19139/present/metadata-
iso19139-edit.xsl only calls escapeXMLEntities (from utils.xsl) for title
2623 <xsl:variable name="title">
2624 <xsl:apply-templates mode="escapeXMLEntities"
select="/root/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:title/gco:CharacterString"/>
2625 </xsl:variable>
which doesnt escape/purge/removes eventual crlfs. For some reason this
blows the returned xml/javascript called when hitting the geopublish
button ? I'm trying to add the abstract/keyword to the things passed to
GeoPublisherPanel so a way to escape/fix purge crlfs and other control
codes would be appreciated.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1229>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by landry):
A workaround is to add the following template to xsl/utils.xsl in the
escapeXMLEntities template :
<xsl:call-template name="replaceString">
<xsl:with-param name="expr"
select="$e4"/>
<xsl:with-param name="pattern"
select="' '"/>
<xsl:with-param name="replacement"
select="'\\n'"/>
</xsl:call-template>
With that, the title string is properly passed to the GeoPublishPanel.
That's quite a hack - but anyway, the title needs to be sanitized from
control chars.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1229#comment:1>
Priority: major | Milestone: v2.8.1
Keywords: |
Changes (by ianwallen):
* milestone: v2.9.0 => v2.8.1
Comment:
Commit in master 0df3a20946e75ff3122a870c8f82d680884cf4fe
Ticket #1232 depends on this request - it still needs to be cherry picked
to the 2.8 branch before closing the ticket.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1229#comment:2>
Type: defect | Status: closed
Resolution: fixed | Keywords:
* status: new => closed
* resolution: => fixed
Comment:
Commit in 2.8 branch 64b8042bbbcc0c1a97b293b7b55e85bcea7c7fb5
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1229#comment:3>
