[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1231: Geopublish doesnt properly send accentued chars in the title
Reporter: landry | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0RC2
Keywords: |
An issue i've been tracking down since some weeks, if my metadata title
contains accentued chars they're not properly sent to GeoServer when
publishing.
Espaces Naturels Sensibles - Département du Cantal - 2013
becomes this in GeoServer layer title
Espaces Naturels Sensibles - D?partement du Cantal - 2013
GeoServer itself properly supports POST/PUT'ing utf-8 encoded xml (ie curl
-X -H"Content-type: text/xml" -d@/tmp/t.xml
http://localhost:9080/wxs/rest/workspaces/public/datastores/CG15_2013_ENS/featuretypes/CG15_2013_ENS
with /tmp/t.xml containing utf-8 chars sets a correctly accentued
title/abstract).
So the issue is on Geonetwork side - afaict, when GET'ing
geoserver.publisher (action=CREATE) upon publish, the chars are url-
encoded :
GET
/geocat/srv/fre/geoserver.publisher?_dc=1362049081712&metadataId=355&metadataUuid=a6a5a793-b9d1-4351
-974a-
fffd20644614&metadataTitle=Espaces%20Naturels%20Sensibles%20-%20%5CnD%C3%A9partement%20du%20Cantal%20-%202013
But when you're in the publisher backend in
web/src/main/java/org/fao/geonet/services/publisher/Do.java Exec() the
metadataTitle doesnt contain utf-8 chars anymore.
Log.debug(MODULE, "metadataTitle="+metadataTitle);
DEBUG [geonetwork.GeoServerPublisher] - metadataTitle=Espaces Naturels
So at some point the encoding is lost before PUT'ing/POST'ing xml to
GeoServer.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1231&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by landry):
There is something definitely weird going on, since my tomcat has
URIEncoding properly set to UTF-8 in server.xml, and using
URLDecoder.decode on the query string returns ?? for accentued letters. A
standalone example in a simple java file works.
import java.net.URLDecoder;
class t {
public static void main (String args) {
try {
     System.out.println( java.net.URLDecoder.decode(args[0],"UTF-8") );
} catch (Exception e) {}
java t foo=bar%C3%A9%C3%A0
foo=baréà
After adding some debug code to jeeves' ServiceRequestFactory.java:
Log.debug(Log.REQUEST,"Decoded queryString "+
URLDecoder.decode(req.getQueryString(), "UTF-8"));
Log.debug(Log.REQUEST, "Query string : "+ req.getQueryString());
[jeeves.request] - Query string : foo=bar%C3%A9%C3%A0
[jeeves.request] - Decoded queryString foo=bar??
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1231#comment:1&gt;
#1231: [patch] Geopublish doesnt properly send accentued chars in the title
Keywords: |
Comment(by landry):
Finally nailed it, it was a tricky one - in fact after comparing the
String lenght and converting it as a byte array, realized the utf chars
were still properly in the string, not rendered in debug log. So it was
down the call stack... and StringRequestEntity ctor was the culprit -
apparently it defaults to encode as default HTTP content charset
(ISO-8859-1).
So the following diff properly encodes all the xml sent by sendREST :
a/web/src/main/java/org/fao/geonet/services/publisher/GeoServerRest.java
b/web/src/main/java/org/fao/geonet/services/publisher/GeoServerRest.java
@@ -661,7 +658,7 @@ public class GeoServerRest {
                         if (postData != null) {
                                 ((PutMethod) m).setRequestEntity(new
StringRequestEntity(
- postData));
+ postData, contentType,
"UTF-8"));
                 } else if (method.equals(METHOD_DELETE)) {
                         m = new DeleteMethod(url);
@@ -669,7 +666,7 @@ public class GeoServerRest {
                         m = new PostMethod(url);
                                 ((PostMethod) m).setRequestEntity(new
- postData));
"UTF-8"));
                 } else {
And the layer definition in GeoServer correctly gets all the accentued
chars - which are properly displayed in the WMS getCapability document.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1231#comment:2&gt;
I designed a customized schema plugin based on ISO19139 due to our organization requirement. All new schema packages and new attributes are working properly.
Following is the sample XML data of schema.
<gmd:MD_Metadata xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns:gmd="http://www.isotc211.org/2005/gmd&quot; xmlns:gco="http://www.isotc211.org/2005/gco&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:srv="http://www.isotc211.org/2005/srv&quot; xsi:schemaLocation="http://www.isotc211.org/2005/gmd/gmd\.xsd http://www.opengis.net/gml/gml\.xsd&quot;&gt;
    <gmd:fileIdentifier>
        <gco:CharacterString>praveshrai</gco:CharacterString>
    </gmd:fileIdentifier>
    <gmd:language>
        <gmd:LanguageCode codeList="http://www.loc.gov/standards/iso639-2/&quot; codeListValue="eng"/>
    </gmd:language>
    <gmd:AbstractDescribingData>
        <gmd:MD_METADATA_IDENTIFY_INFO>
            <gco:CharacterString>SOI-OSM Sheet-G 46M/1</gco:CharacterString>
        </gmd:MD_METADATA_IDENTIFY_INFO>
        <gmd:MD_Data_Identify_abstract>
            <gco:CharacterString>The data shows boundary lines sourced from GSI geological map on 1:50,000 scales.The data is in shape file formate.</gco:CharacterString>
        </gmd:MD_Data_Identify_abstract>
    </gmd:AbstractDescribingData>
    <gmd:Citation>
        <gmd:Data_Prepared_By>
            <gco:CharacterString>Geological Survey of India</gco:CharacterString>
        </gmd:Data_Prepared_By>
        <gmd:Original_Source>
            <gco:CharacterString>1:50K Geological Map</gco:CharacterString>
        </gmd:Original_Source>
        <gmd:Source_Scale_Date>
            <gco:CharacterString>1:50K</gco:CharacterString>
        </gmd:Source_Scale_Date>
        <gmd:Mapping_Year>
            <gco:CharacterString>1982</gco:CharacterString>
        </gmd:Mapping_Year>
        <gmd:Digitizing_Year>
            <gco:CharacterString>2006</gco:CharacterString>
        </gmd:Digitizing_Year>
        <gmd:survey_year>
            <gco:CharacterString>1962</gco:CharacterString>
        </gmd:survey_year>
        <gmd:Lineage>
            <gco:CharacterString> G 46M/1</gco:CharacterString>
        </gmd:Lineage>
        <gmd:Associated_project_data>
            <gco:CharacterString>NA</gco:CharacterString>
        </gmd:Associated_project_data>
        <gmd:Associated_Publications>
        </gmd:Associated_Publications>
        <gmd:Person_Email>
            <gco:CharacterString>hod.ner@anonymised.com</gco:CharacterString>
        </gmd:Person_Email>
        <gmd:Person_Affiliation>
            <gco:CharacterString>Centre Govt.</gco:CharacterString>
        </gmd:Person_Affiliation>
        <gmd:Corporate_Name>
        </gmd:Corporate_Name>
        <gmd:Corporate_Address>
            <gco:CharacterString>Dy. Director General, Geological Survey of India, 'Shylla Building', Nongrim Hills, Shillong, Meghalaya-793003</gco:CharacterString>
        </gmd:Corporate_Address>
    </gmd:Citation>
    <gmd:coverageElement>
        <gmd:Coverage>
            <gmd:geographicElement>
                <gmd:EX_GeographicBoundingBox>
                    <gmd:xmin>
                        <gco:Decimal>90.004532</gco:Decimal>
                    </gmd:xmin>
                    <gmd:xmax>
                        <gco:Decimal>90.237898</gco:Decimal>
                    </gmd:xmax>
                    <gmd:ymin>
                        <gco:Decimal>25.779184</gco:Decimal>
                    </gmd:ymin>
                    <gmd:ymax>
                        <gco:Decimal>25.92735</gco:Decimal>
                    </gmd:ymax>
                </gmd:EX_GeographicBoundingBox>
            </gmd:geographicElement>
            <gmd:tlate>
            </gmd:tlate>
            <gmd:tearly>
            </gmd:tearly>
            <gmd:Place_Name>
                <gco:CharacterString>Shillong, Meghalaya</gco:CharacterString>
            </gmd:Place_Name>
            <gmd:Period_Name>
            </gmd:Period_Name>
            <gmd:spatial_resolution>
            </gmd:spatial_resolution>
            <gmd:spatial_georeference>
            </gmd:spatial_georeference>
            <gmd:spatial_aggregation>
                <gco:CharacterString>G 46M/1</gco:CharacterString>
            </gmd:spatial_aggregation>
            <gmd:temporal_precision>
            </gmd:temporal_precision>
            <gmd:temporal_interval>
            </gmd:temporal_interval>
            <gmd:temporal_aggregation>
            </gmd:temporal_aggregation>
            <gmd:note>
            </gmd:note>
            <gmd:Alternative_Metadata>
            </gmd:Alternative_Metadata>
        </gmd:Coverage>
    </gmd:coverageElement>
    <gmd:DataIdentificationInformation>
        <gmd:id>
        </gmd:id>
        <gmd:Name_of_Dataset>
            <gco:CharacterString>Map50K-Dyke</gco:CharacterString>
        </gmd:Name_of_Dataset>
        <gmd:Name_of_data>
            <gco:CharacterString>Map50K-Dyke-1982-G 46M/1</gco:CharacterString>
        </gmd:Name_of_data>
        <gmd:Theme>
            <gco:CharacterString>Geology</gco:CharacterString>
        </gmd:Theme>
        <gmd:Keywords>
            <gco:CharacterString>1:50K, Dyke, GSI</gco:CharacterString>
        </gmd:Keywords>
        <gmd:Access_Constraints>
            <gco:CharacterString>As per GSI Data Dissemination Policy</gco:CharacterString>
        </gmd:Access_Constraints>
        <gmd:Use_Constraints>
        </gmd:Use_Constraints>
        <gmd:Purpose_of_creating_Data>
            <gco:CharacterString>To generate digital geological database</gco:CharacterString>
        </gmd:Purpose_of_creating_Data>
        <gmd:Data_Type>
            <gco:CharacterString>Vector</gco:CharacterString>
        </gmd:Data_Type>
        <gmd:Agency_Id>
            <gco:CharacterString>2</gco:CharacterString>
        </gmd:Agency_Id>
        <Agency_Name>
        </Agency_Name>
    </gmd:DataIdentificationInformation>
    <gmd:ContactInformation>
        <gmd:Contact_Person>
            <gco:CharacterString>Director, Geodata Division</gco:CharacterString>
        </gmd:Contact_Person>
        <gmd:Organization>
        </gmd:Organization>
        <gmd:Mailing_Address>
        </gmd:Mailing_Address>
        <gmd:City_locality>
        </gmd:City_locality>
        <gmd:Country>
            <gco:CharacterString>India</gco:CharacterString>
        </gmd:Country>
        <gmd:Contact_Telephone>
            <gco:CharacterString>(0364)2520228</gco:CharacterString>
        </gmd:Contact_Telephone>
        <gmd:Contact_Fax>
            <gco:CharacterString>0364-2520033</gco:CharacterString>
        </gmd:Contact_Fax>
        <gmd:Contact_Email>
        </gmd:Contact_Email>
    </gmd:ContactInformation>
    <gmd:MetadataDateStamp>
        <gmd:MD_Metadata_date_Stamp>
        </gmd:MD_Metadata_date_Stamp>
        <gmd:ISO08601>
        </gmd:ISO08601>
    </gmd:MetadataDateStamp>
    <gmd:DatasetTopicCategory>
        <gmd:MD_Data_Identify_Category>
            <gco:CharacterString>Geoscientific Information</gco:CharacterString>
        </gmd:MD_Data_Identify_Category>
    </gmd:DatasetTopicCategory>
    <gmd:Language>
        <gmd:language_ISO0639_2Bsh>
            <gco:CharacterString>English</gco:CharacterString>
        </gmd:language_ISO0639_2Bsh>
    </gmd:Language>
    <gmd:ForImageData>
        <gmd:Name_of_the_Satellite>
        </gmd:Name_of_the_Satellite>
        <gmd:Sensor>
        </gmd:Sensor>
        <gmd:Path>
        </gmd:Path>
        <gmd:Row_no>
        </gmd:Row_no>
        <gmd:Image_Acquired_From>
        </gmd:Image_Acquired_From>
        <gmd:Date_and_Time_of_Image>
        </gmd:Date_and_Time_of_Image>
        <gmd:File_Format>
        </gmd:File_Format>
        <gmd:Bits_per_Pixel>
        </gmd:Bits_per_Pixel>
        <gmd:Spatial_Resolution>
        </gmd:Spatial_Resolution>
        <gmd:Spatial_Resolution_Unit>
        </gmd:Spatial_Resolution_Unit>
        <gmd:Number_of_Bands>
        </gmd:Number_of_Bands>
        <gmd:Number_of_Rows>
        </gmd:Number_of_Rows>
        <gmd:Number_of_Cols>
        </gmd:Number_of_Cols>
    </gmd:ForImageData>
</gmd:MD_Metadata>
I have following issues to use search functionality-
1- With GN search GUI, I am not able to see Title and abstract fields in search result, because my schema has different fields,
  * How to map my customized fields to be displayed metadata search results in GN GUI,I had tried to configure config-csw.xml, config-lucene.xml, index-fields.xml, with following setting-
Config-csw.xml-
<parameter name="NSDITheme" field="Theme" type="SupportedISOQueryables">
                    <xpath schema="iso19139" path="gmd:DataIdentificationInformation/gmd:Theme/gco:CharacterString"/>
</parameter>
config-lucene.xml- dump field section
  <field name="NSDITheme" tagName="Theme"/>
    </dumpFields>
Index-fields
<xsl:for-each select="gmd:DataIdentificationInformation/gmd:Theme/gco:CharacterString">
    <Field name="NSDITheme" string="{string(.)}" store="true" index="true"/>
  </xsl:for-each>
2- On using xml.search and q query search as http://localhost:8080/geonetwork/srv/en/q?fast=index , I am not able to get my schemas' dumped fields configured in config-lucene.xml
Any suggestions and help is highly appreciable.
Thanks and regards
Vimlesh Bahuguna
Hi Vimal
You need to index title, _title and abstract lucene fields for your profile. See iso1939 index-fields.xsl for these fields and manage about similar indexing using the fields in your profile that have this information.
2- On using xml.search and q query search as http://localhost:8080/geonetwork/srv/en/q?fast=index , I am not able to get my schemas’ dumped fields configured in config-lucene.xml
To get the fields in q service you can add your fields in WEB-INF/config-lucene.xml , inside the dumpFields section. To get them in xml.search if not wrong requires Java changes (see buildInfoElem in DataManager).
Jose García
On Fri, Mar 1, 2013 at 7:37 AM, Vimal Bahuguna <bahuguna.vimal@anonymised.com> wrote:
<gmd:MD_Metadata xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:gmd=“http://www.isotc211.org/2005/gmd” xmlns:gco=“http://www.isotc211.org/2005/gco” xmlns:gml=“http://www.opengis.net/gml” xmlns:xlink=“http://www.w3.org/1999/xlink” xmlns:srv=“http://www.isotc211.org/2005/srv” xsi:schemaLocation=“http://www.isotc211.org/2005/gmd http://www.isotc211.org/2005/gmd/gmd.xsd http://www.opengis.net/gml http://www.opengis.net/gml/gml.xsd”>
gmd:fileIdentifier
gco:CharacterStringpraveshrai</gco:CharacterString>
gmd:language
<gmd:LanguageCode codeList=“http://www.loc.gov/standards/iso639-2/” codeListValue=“eng”/>
</gmd:language>
gco:CharacterStringSOI-OSM Sheet-G 46M/1</gco:CharacterString>
gco:CharacterStringThe data shows boundary lines sourced from GSI geological map on 1:50,000 scales.The data is in shape file formate.</gco:CharacterString>
gmd:Citation
gco:CharacterStringGeological Survey of India</gco:CharacterString>
gmd:Original_Source
gco:CharacterString1:50K Geological Map</gco:CharacterString>
gco:CharacterString1:50K</gco:CharacterString>
gmd:Mapping_Year
gco:CharacterString1982</gco:CharacterString>
</gmd:Mapping_Year>
gmd:Digitizing_Year
gco:CharacterString2006</gco:CharacterString>
gmd:survey_year
gco:CharacterString1962</gco:CharacterString>
</gmd:survey_year>
gmd:Lineage
gco:CharacterString G 46M/1</gco:CharacterString>
</gmd:Lineage>
gco:CharacterStringNA</gco:CharacterString>
gmd:Person_Email
gco:CharacterStringhod.ner@anonymised.com</gco:CharacterString>
</gmd:Person_Email>
gco:CharacterStringCentre Govt.</gco:CharacterString>
gmd:Corporate_Name
gco:CharacterStringDy. Director General, Geological Survey of India, ‘Shylla Building’, Nongrim Hills, Shillong, Meghalaya-793003</gco:CharacterString>
</gmd:Citation>
gmd:coverageElement
gmd:Coverage
gmd:xmin
gco:Decimal90.004532</gco:Decimal>
</gmd:xmin>
gmd:xmax
gco:Decimal90.237898</gco:Decimal>
</gmd:xmax>
gmd:ymin
gco:Decimal25.779184</gco:Decimal>
</gmd:ymin>
gmd:ymax
gco:Decimal25.92735</gco:Decimal>
</gmd:ymax>
gmd:tlate
</gmd:tlate>
gmd:tearly
</gmd:tearly>
gmd:Place_Name
gco:CharacterStringShillong, Meghalaya</gco:CharacterString>
</gmd:Place_Name>
gmd:Period_Name
</gmd:Period_Name>
gco:CharacterStringG 46M/1</gco:CharacterString>
gmd:note
</gmd:note>
</gmd:Coverage>
gmd:id
</gmd:id>
gmd:Name_of_Dataset
gco:CharacterStringMap50K-Dyke</gco:CharacterString>
gmd:Name_of_data
gco:CharacterStringMap50K-Dyke-1982-G 46M/1</gco:CharacterString>
</gmd:Name_of_data>
gmd:Theme
gco:CharacterStringGeology</gco:CharacterString>
</gmd:Theme>
gmd:Keywords
gco:CharacterString1:50K, Dyke, GSI</gco:CharacterString>
</gmd:Keywords>
gco:CharacterStringAs per GSI Data Dissemination Policy</gco:CharacterString>
gmd:Use_Constraints
gco:CharacterStringTo generate digital geological database</gco:CharacterString>
gmd:Data_Type
gco:CharacterStringVector</gco:CharacterString>
</gmd:Data_Type>
gmd:Agency_Id
gco:CharacterString2</gco:CharacterString>
</gmd:Agency_Id>
<Agency_Name>
</Agency_Name>
gmd:Contact_Person
gco:CharacterStringDirector, Geodata Division</gco:CharacterString>
gmd:Organization
</gmd:Organization>
gmd:Mailing_Address
gmd:City_locality
gmd:Country
gco:CharacterStringIndia</gco:CharacterString>
</gmd:Country>
gco:CharacterString(0364)2520228</gco:CharacterString>
gmd:Contact_Fax
gco:CharacterString0364-2520033</gco:CharacterString>
</gmd:Contact_Fax>
gmd:Contact_Email
gmd:ISO08601
</gmd:ISO08601>
gco:CharacterStringGeoscientific Information</gco:CharacterString>
gmd:Language
gco:CharacterStringEnglish</gco:CharacterString>
</gmd:Language>
gmd:ForImageData
gmd:Sensor
</gmd:Sensor>
gmd:Path
</gmd:Path>
gmd:Row_no
</gmd:Row_no>
gmd:File_Format
</gmd:File_Format>
gmd:Bits_per_Pixel
gmd:Number_of_Bands
gmd:Number_of_Rows
gmd:Number_of_Cols
</gmd:ForImageData>
</gmd:MD_Metadata>
  • How to map my customized fields to be displayed metadata search results in GN GUI,I had tried to configure config-csw.xml, config-lucene.xml, index-fields.xml, with following setting-
Config-csw.xml-
Index-fields
<xsl:for-each select=“gmd:DataIdentificationInformation/gmd:Theme/gco:CharacterString”>
</xsl:for-each>
Thanks and regards
Vimlesh Bahuguna
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_feb
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by ianwallen):
  * status: new => closed
  * resolution: => fixed
Comment:
Commit in master ad83740d136a7f7423388b785489e3560a9b0db8
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1231#comment:3&gt;
