[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1233: OGC WebServices harvester doesn't work in 2.8.x
Reporter: josegar74 | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: blocker | Milestone: v2.8.0
Component: General | Version: v2.8.0RC2
Keywords: |
Configuring a WMS harvester and running it returns:
{{{javax.xml.transform.TransformerConfigurationException}}}
In the log:
Error at xsl:include on line 3 column 117 of OGCWMSGetCapabilities-to-
ISO19119_ISO19139.xsl:
   XTSE0165: java.io.FileNotFoundException:
   ../geonetwork/WEB-INF/data/xsl/conversion/OGCWxSGetCapabilitiesto19119
/OGCWxSGetCapabilities-to-19119.xsl (No such file or directory)
2013-03-06 18:55:18,903 WARN [geonetwork.harvester] - Raised exception
while harvesting from : catastro (OgcWxSHarvester)
2013-03-06 18:55:18,903 WARN [geonetwork.harvester] - (C) Class :
2013-03-06 18:55:18,903 WARN [geonetwork.harvester] - (C) Message :
Failed to compile stylesheet. 1 error detected.
javax.xml.transform.TransformerConfigurationException: Failed to compile
         at
net.sf.saxon.PreparedStylesheet.prepare(PreparedStylesheet.java:176)
         at
net.sf.saxon.TransformerFactoryImpl.newTemplates(TransformerFactoryImpl.java:139)
Seem expects xsl files in {{{WEB-INF/data/xsl}}}
If copying this folder manually, no more that error, but then:
{{{Root element not set}}}
Didn't test in 2.9.x
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1233&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Is this the same as ticket #910?
There is a patch for that. As far as I can tell that patch fixes the
problem. I was hoping that patch would make it into the 2.8 release. Can it
be included in 2.8.1? Or is there a problem with it?
Byron
View this message in context: http://osgeo-org.1560.n6.nabble.com/GeoNetwork-opensource-Developer-website-1233-OGC-WebServices-harvester-doesn-t-work-in-2-8-x-tp5038842p5039263.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by josegar74):
  * status: new => closed
  * resolution: => fixed
Comment:
Related to #910 (seem was only committed in master branch).
Committed #910 in 2.8.x: 3fa78361173486c0352589cf30267bf8d028776b
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1233#comment:1&gt;
  Priority: blocker | Milestone: v2.8.1
Changes (by ianwallen):
  * milestone: v2.8.0 => v2.8.1
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1233#comment:2&gt;
