[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1238: generated schematron scontain attributes without name yielding errors in the validator
the validator
Reporter: landry | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0
Keywords: |
Symptoms are WARNING: schematron xslt
/data/webapps/geonetwork/2.8.0/dev/config/schema_plugins/iso19139
/schematron-rules-geonetwork.xsl failed (and the same on schematron-rules-
iso.xsl).
This yields error in catalina.out in
org.fao.geonet.kernel.DataManager.getSchemaTronXmlReport(DataManager.java:876)
Error at xsl:attribute on line 384 column 16 of schematron-rules-iso.xsl:
   XTSE0010: Element must have a "name" attribute
Error at xsl:attribute on line 391 column 16 of schematron-rules-iso.xsl:
Error at xsl:attribute on line 394 column 16 of schematron-rules-iso.xsl:
In turn the validation window shows 'Schematron error ocurred, rules could
not be verified: Failed to compile stylesheet. 46 errors detected.' (for
-geonetwork.xsl it's only 2 errors)
Looking at the generated file in schematrons/.build/schematron-rules-
geonetwork.xsl (smaller amount of errors than -iso)
<svrl:ns-prefix-in-attribute-values/>
<svrl:active-pattern>
<xsl:attribute>
<value-of/>
</xsl:attribute>
<xsl:attribute>
<xsl:value-of/>
</xsl:attribute>
the xsl:attribute tags have no 'name' attribute, thus yielding this
warning.
As i dont really understand how this section comes from
iso_svrl_for_xslt2.xsl ( the process-pattern template ? ) i'll let it to
someone who knows this part to explain it.
Or noone can reproduce that ? Or it's dependent on some version of a
processor at some point ?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1238&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
the validator
Keywords: |
Comment(by landry):
Note that if i manually set the attribute name to 'none' and do 'save and
validate' there's no validation error shown to the user, but the following
is shown the datamanager debug log :
   <geonet:report geonet:rule="schematron-rules-geonetwork">
     <svrl:schematron-output xmlns:svrl="http://purl.oclc.org/dsdl/svrl&quot;
xmlns:gmd="http://www.isotc211.org/2005/gmd&quot;
xmlns:srv="http://www.isotc211.org/2005/srv&quot;
xmlns:gco="http://www.isotc211.org/2005/gco&quot;
xmlns:schold="http://www.ascc.net/xml/schematron&quot;
xmlns:xs="http://www.w3.org/2001/XMLSchema&quot;
xmlns:xlink="http://www.w3.org/1999/xlink&quot;
xmlns:iso="http://purl.oclc.org/dsdl/schematron&quot;
xmlns:xhtml="http://www.w3.org/1999/xhtml&quot;
xmlns:gml="http://www.opengis.net/gml&quot; title="Schematron validation /
GeoNetwork recommendations" schemaVersion="">
       <svrl:ns-prefix-in-attribute-values />
       <svrl:active-pattern none="" />
     </svrl:schematron-output>
   </geonet:report>
The three ? ? ? seem to come from utf-8 chars
./.build/schematron-rules-geonetwork.xsl: <xsl:value-of
select="$archiveDirParameter"/> Â|
./resources/iso_svrl_for_xslt2.xsl: <axsl:comment><axsl
:value-of select="$archiveDirParameter"/> &#xA0;
And the rest of the message sounds like if the full following section
wasnt supposed to be here.
<xsl:attribute name="none">
<value-of/>
</xsl:attribute>
<xsl:value-of/>
</xsl:attribute>
<xsl:apply-templates/>
</svrl:active-pattern>
I can comment it out completely, no errors are shown anymore - but i'd
just like to ensure this is a real bug.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1238#comment:1&gt;
