#1243: mvn jetty:run causes TransformerConfigurationException with “Failed to
compile stylesheet. xx errors...."
Reporter: simonp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: minor | Milestone: v2.8.1
Component: General | Version: v2.8.0
Keywords: |
Problem is that mvn jetty:run (as used by devs) adds current schema plugin
config to the schemaplugin-uri-catalog.xml in src/webapp/WEB-
INF/data/config (thanks to fxp for that diagnosis) - this would cause all
installations built from this src tree to fail.
Fix is to reconfig the schemaplugin-uri-catalog.xml (for urls needed by
XSLT engine) at startup with the installed schema plugins (this is done in
SchemaManager init) - benefit is that installation can now be moved
without causing issues here as well.
See commit a3131b7d850ddb887c720749ced1541d02708d51
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1243>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
