#1247: Indexing / iso19139 / add XSL mode to easily add new field in a profile
Reporter: fxp | Owner: geonetwork-devel@…
Priority: minor | Milestone: v2.9.0
Component: General | Version: v2.9.0
Keywords: PIGMA |
When making a profile, indexing could be quite easily delegated to
iso19139 using:
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
version="2.0">
<xsl:import href="../iso19139.fra/index-fields.xsl"/>
</xsl:stylesheet>
but there is no easy way to add one field (without duplicating the
mode="metadata" template).
This task adds an "index" mode template in order to easily add new field.
For example, index some keywords from a specific thesaurus in a new field
adding the following to the previous XSL:
<xsl:template mode="index"
match="gmd:MD_Keywords[gmd:thesaurusName/gmd:CI_Citation/
gmd:title/gco:CharacterString='My thesaurus']/
gmd:keyword[normalize-space(gco:CharacterString)
<Field name="myThesaurusKeyword" string="{string(.)}"
store="true" index="true"/>
</xsl:template>
If matching a upper level element, apply mode to its child to further
index deeper level if required:
<xsl:template mode="index" match="gmd:EX_Extent">
... do something
... and continue indexing
<xsl:apply-templates mode="index" select="*"/>
</xsl:template>
No changes made to mode="metadata" for compatibility with existing
profiles.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1247>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
