[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1250: ISO19139 / Improve support for making metadata on maps
Reporter: fxp | Owner: geonetwork-devel@…
     Type: task | Status: new
Priority: minor | Milestone: v2.9.0
Component: General | Version: v2.9.0
Keywords: GEOPICARDIE |
The goal is to help user describing maps using ISO19139 providing:
  * a template
  * a quick search for maps using resource type criteria
  * minor changes to the editor for maps (eg. suggestion for formats)
Changes:
  * Index ISO19139 record describing maps with field "type" equal "map"
when:
   * gmd:hierarchyLevel/gmd:MD_ScopeCode/@codeListValue='dataset'
gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:presentationForm/gmd:CI_PresentationFormCode/@codeListValue
= 'mapDigital'
gmd:distributionInfo/gmd:MD_Distribution/gmd:distributionFormat/gmd:MD_Format/gmd:name/gco:CharacterString[contains(.,
'PDF') or contains(., 'PNG') or contains(., 'JPEG') or contains(.,
'OGC:WMC') or contains(., 'OGC:OWS')])
   * if distribution format is PDF : "type"="staticMap" is also added to
the index
   * if distribution format is OGC:WMC or OGC:OWS : "type"="interactiveMap"
is added to the index
  * Search form / Add search for map in resource type
  * Templates:
   * Add an ISO19139 template for maps
   * Remove presentationForm from default raster and vector templates
  * Editor / Add values for format suggestion
   * PDF
   * PNG
   * JPEG
   * OGC:WMC
   * OGC:OWS Context
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1250&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Comment(by guillaume):
I guess I would add 'GIF', 'BMP' and 'TIFF' as well for the format values,
even if they are not the most common types.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1250#comment:1&gt;
Comment(by fxp):
TIFF is already here (used for RASTER layer too).
Why not for GIF and BMP.
The list of suggestion is simply defined in localization files and could
be customized easily. It's sometimes better to not to have too many
options (in case you use radio mode for suggestion for example - see
http://trac.osgeo.org/geonetwork/ticket/1211).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1250#comment:2&gt;
Description changed by fxp:
Old description:
* a template
Changes:
when:
= 'mapDigital'
the index
"type"="interactiveMap" is added to the index
* Templates:
  * PDF
  * PNG
  * JPEG
  * OGC:WMC
  * OGC:OWS Context
New description:
  * a template
Changes:
when:
= 'mapDigital'
the index
  * Search form / Add search for map in resource type - based on
autocompletion
  * Search results : For WMC, add "add to map" action to load the context
in the mapviewer
  * Templates:
   * PDF
   * PNG
   * JPEG
   * OGC:WMC
   * OGC:OWS Context
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1250#comment:3&gt;
      Type: task | Status: closed
Resolution: fixed | Keywords: GEOPICARDIE
Changes (by fxp):
  * status: new => closed
  * resolution: => fixed
Comment:
master commit 1e85b55e9faf9ba22728fb864751e69b0f729bb2
     ISO19139 / Improve support for making metadata on maps (#1250).
master commit 79688176a423f2d4d07b89e6dbd75f79a5b418dd
     Load WMC / Add load.wmc service to the allowed services. Remove old
intermap services.
master commit e57e1ad81b3aa0d14085ce900f6b801fd33d4d1b
     Load WMC / Fix error related to OL 2.12 update.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1250#comment:4&gt;
