#1252: Thesaurus / GCMD keywords loading error
Reporter: fxp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.9.0
Component: General | Version: v2.8.0
Keywords: |
I attempted to load the GCMD keywords (sciencekeywords.rdf) from
http://gcmdservices.gsfc.nasa.gov/static/kms/sciencekeywords/ using the
manage thesauri and got an error.
2013-03-21 13:53:56,484 ERROR [jeeves.service] - Exception when executing
service
2013-03-21 13:53:56,484 ERROR [jeeves.service] - (C) Exc :
org.openrdf.sesame.config.ConfigurationException:
org.openrdf.sesame.sail.SailInitializationException: Parse error on li
ne -1
2013-03-21 13:53:56,485 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
<message>org.openrdf.sesame.sail.SailInitializationException: Parse
error on line -1</message>
<class>ConfigurationException</class>
<stack>
<at class="org.openrdf.sesame.repository.local.LocalService"
file="LocalService.java" line="417" method="_createRepository" />
file="LocalService.java" line="238" method="getRepository" />
file="LocalService.java" line="298" method="createRepository" />
<at class="org.fao.geonet.kernel.ThesaurusManager"
file="ThesaurusManager.java" line="365" method="createThesaurusRepository"
file="ThesaurusManager.java" line="332" method="addThesaurus" />
<at class="org.fao.geonet.services.thesaurus.Upload"
file="Upload.java" line="244" method="UploadThesaurus" />
file="Upload.java" line="193" method="upload" />
removing in the file
<gcmd:termsOfUse xmlns:gcmd="http://gcmd.gsfc.nasa.gov/">See
http://gcmd.nasa.gov/r/l/TermsOfUse</gcmd:termsOfUse>
<gcmd:keywordVersion
xmlns:gcmd="http://gcmd.gsfc.nasa.gov/">7\.0</gcmd:keywordVersion>
<gcmd:schemeVersion xmlns:gcmd="http://gcmd.gsfc.nasa.gov/">2013\-03\-13
16:36:41</gcmd:schemeVersion>
fix the issue.
To be investigated why it's failing.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1252>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
