[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1267: Editor / Expand element error
Reporter: fxp | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: minor | Milestone: v2.9.0
Component: General | Version: v2.9.0
Keywords: |
There is an issue when requesting expansion of an element with or without
suggestion. Improve mechanism. The following cases are documented:
         <!-- Expand optional element gmd:type (gmd:keyword is mandatory
and will be expanded) -->
         <!--<field name="gmd:MD_Keywords">
                 <suggest name="gmd:type"/>
         </field>-->
         <!-- Expand optional element gmd:type and gmd:thesaurusName.
gmd:thesaurusName will
         be expanded including all its mandatory children and optional
suggestion. In that
         case, thesaurus title and date type will be expanded.
Unfortunately, the date is a choice
         between date and dateTime and will not be expanded. -->
<!-- <field name="gmd:MD_Keywords">
                 <suggest name="gmd:thesaurusName"/>
         </field>-->
                 This is not supported because gmd:date is an OR element
with Date or DateTime choice.
                 <field name="gmd:date">
                 <suggest name="gco:Date"/>
         </field>-->
         <!-- Control substitute of gco:CharacterString -->
         <!-- Only propose gco:CharacterString and expand it when
gmd:keyword is created. For this,
         set no suggestion. Adding :
         <field name="gmd:keyword">
                 <suggest name="gco:CharacterString"/>
         </field>
         will not change anything because gco:CharacterString is the
default element.
         <!-- Propose 2 substitutes. A selection list will be displayed to
choose between the 2 elements -->
                 <suggest name="gmx:Anchor"/>
         </field>
Related topic: http://osgeo-org.1560.x6.nabble.com/Issue-adding-elements-
in-metadata-editor-td5040124.html#a5040329
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1267&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by fxp):
  * status: new => closed
  * resolution: => fixed
Comment:
master commit 3022a51a9d3eddc6e1bfb7e435a120976226c95c
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1267#comment:1&gt;
