#1280: Harvester / XSL error
Reporter: fxp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: v2.10.0 RC1
Component: General | Version: v2.10.0RC0
Keywords: |
- HTML Request (from 127.0.0.1) : /geonetwork/srv/eng/harvesting
2013-05-02 09:19:44,807 DEBUG [jeeves.request] - Method : GET
2013-05-02 09:19:44,807 DEBUG [jeeves.request] - Content type : null
2013-05-02 09:19:44,807 DEBUG [jeeves.request] - Accept :
text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2013-05-02 09:19:44,807 DEBUG [jeeves.request] - Session id is
6s7w07zxhxsl1irljdfqctfo8
2013-05-02 09:19:44,808 INFO [jeeves.service] - Dispatching : harvesting
2013-05-02 09:19:44,808 DEBUG [jeeves.service] - -> no input parameters
2013-05-02 09:19:44,808 INFO [jeeves.service] - -> dispatching to
output for : harvesting
2013-05-02 09:19:44,902 INFO [jeeves.service] - -> transforming with
stylesheet :
/tmp/geonetwork210/web/geonetwork/xsl/harvesting/harvesting.xsl
Error at xsl:template on line 28 column 44 of ogcwxs.xsl:
XTSE0660: Duplicate named template (see line 29 of
file:/tmp/geonetwork210/web/geonetwork/xsl/harvesting/arcsde/arcsde.xsl)
Error at xsl:call-template on line 12 column 58 of ogcwxs.xsl:
XTSE0650: No template exists named ownerGroup-OGCWXS
Error at xsl:call-template on line 11 column 63 of z3950Config.xsl:
XTSE0650: No template exists named ownerGroup-Z3950Config
2013-05-02 09:19:45,149 ERROR [jeeves.service] - -> exception during
transformation for : harvesting
2013-05-02 09:19:45,149 ERROR [jeeves.service] - -> (C) stylesheet :
2013-05-02 09:19:45,149 ERROR [jeeves.service] - -> (C) message :
Failed to compile stylesheet. 3 errors detected.
2013-05-02 09:19:45,149 ERROR [jeeves.service] - -> (C) exception :
TransformerConfigurationException
2013-05-02 09:19:45,150 DEBUG [jeeves.service] - Raised exception
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1280>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
