#1295: JSP and UTF-8
Reporter: ianwallen | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.10.0 RC3
Component: User interface (web) | Version: v2.10.0RC2
Keywords: |
If I attempted to login using invalid credentials (using the classic
interface) I get an "HTTP ERROR 500" (see error below)
After looking at the webdefault.xml in the jetty folder I noticed that
javaEncoding defaults to UTF-8. So I convert my login.jsp to UTF-8 format
then all works well.
So my question is - where should this be fixed.
* Should we ensure all *.jsp are in UTF-8 encoding?
* Should be adjust to webdefault.xml to specify another encoding?
* Should it be part of the build process to ensure all *.jsp are in UTF-8
format?
* Other options?
java.lang.ClassNotFoundException: org.apache.jsp.login_jsp
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at
org.apache.jasper.servlet.JasperLoader.findClass(JasperLoader.java:204)
at
org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:190)
at
org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:122)
at
org.apache.jasper.JspCompilationContext.load(JspCompilationContext.java:639)
at
org.apache.jasper.servlet.JspServletWrapper.getServlet(JspServletWrapper.java:192)
at
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:372)
at
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:486)
at
org.apache.jasper.servlet.JspServlet.service(JspServlet.java:380)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at
org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:534)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1352)
at
org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1323)
at
org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
at
at
org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at
org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at
org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
at
at
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:178)
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:155)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:237)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
at
at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at
at
org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:474)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)
at
org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:480)
at
org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at
org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:934)
at
org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:404)
at
org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:184)
at
org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:869)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at
org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:247)
at
org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:151)
at
org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:346)
at
org.eclipse.jetty.server.HttpConnection.handleRequest(HttpConnection.java:581)
at
org.eclipse.jetty.server.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:1040)
at
org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:592)
at
org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:214)
at
org.eclipse.jetty.server.HttpConnection.handle(HttpConnection.java:411)
at
org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:526)
at
org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:41)
at
org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:528)
at java.lang.Thread.run(Thread.java:679)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1295>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
