#132: GAST Synchronize does not work
Reporter: ticheler | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: major | Milestone: v2.4.0 RC2
Component: GAST | Version: v2.4.0 Final
Keywords: |
On OS X I tried to run the Synchronize function of GAST to change the URLs
in metadata from localhost into 127.0.0.1
The process silently fails and no changes have been made to the metadata.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/132>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
Resolution: | Keywords:
Comment (by simonp):
Works ok on Linux, Windoze using latest trunk - change was made at trunk
svn rev 4546 (after rc2 unfortunately) so that gast picks up the saxon
xslt engine - does it work on OSX with that change?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/132#comment:1>
Type: defect | Status: closed
Resolution: invalid | Keywords:
Changes (by ticheler):
* status: new => closed
* resolution: => invalid
Comment:
Works also on OS X. I should have shut down the web application first...
We should add an instruction in GAST, including a warning in case GN is
running so the synching can not be performed.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/132#comment:2>
