#165: "unable to open resource main-db" returned by metadata.show and
xml.iso19139 services - stalls server?
Reporter: simonp | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: major | Milestone: v2.4.1
Component: General | Version: v2.5.0
Keywords: |
Reported by Heikki Doeleman:
________________________________________
Sent: Wednesday, 21 October 2009 3:02 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] "unable to open resource main-db"
Heikki,
I'm also seeing this problem after doing repeated saves. I'm using oracle,
with pool size = 10 and reconnectTime=undefined. Problem is not easily
repeatable, but happens regularly.
Is this a problem with the connection pool running out of objects?
Reading the code, I'm somewhat confused as to how the connection pool is
supposed to work, and resources get released. By my reading, the only
place
connections get released is by calling close on connection pool object
(DbmsPool) with the resource (Dbms) as an argument, which unlocks the
resource.
However, in the code, this never seems to be done. The default pattern
seems
to be to get a new resource with
dbms = context.getResourceManager().open(Geonet.Res.MAIN_DB)
and then to leave the resource to go out of scope
Yours, mystified, and frustrated at not being able to track down the
error....
Anybody else got any ideas?
James
Heikki Doeleman wrote:
> hello lists,
> I'm seeing this error, every so often :
> **"unable to open resource main-db after 20attempts"
> This happens when you're using the editor for a bit. When it happens,
you
> must either restart GeoNetwork or wait a while (session timeout?).
> It started to happen for us after moving to Postgres and moving to a GN
> 2.4-based application.
> A search on Google shows that quite lots of GeoNetwork nodes have it.
> Moreover, from a WHO node that displays a stacktrace, it seems they have
> it
> when using MySQL, not Postgres (
http://209.85.229.132/search?q=cache:5Z0sxBf6fS8J:apps.who.int/geonetwork/srv/en/metadata.show%3Fid%3D74%26currTab%3Dsimple+"unable+to+open+resource+
main-
db%22+%22Communications+link+failure+due+to+underlying+exception:%22&cd=1&hl=en&ct=clnk
> Does anybody know what to do to prevent this from ever happening ? My
JDBC
> settings in config.xml are poolSize=10, reconnectTime=undefined
> (defaulting
> to Jeeves).
> Thank you so much
> Kind regards
> Heikki Doeleman
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/165>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
