#166: bug in massive ownership transfer
Reporter: simonp | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: major | Milestone: v2.4.2
Component: General | Version: v2.5.0
Keywords: |
I get an error message when trying to perform massive ownership transfer :
PSQLException : ERREUR: la colonne � owner � est de type integer mais
l'expression est de type character varying
[in english : the column 'owner' is of type Integer, but the expression is
of type character varying]
I'm using postgreSQL.
It looks like it comes from geonet/kernel/DataManager.java : changing the
owner and gourpOwner type to integer resvoles it :
public synchronized void updateMetadataOwner(UserSession session, Dbms
dbms, int id, String owner, String groupOwner) throws Exception
dbms.execute("UPDATE Metadata SET owner=?, groupOwner=? WHERE
id=?", new Integer(owner), new Integer(groupOwner), id);
Jean
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/166>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
