#173: MEF2 support
Reporter: fxp | Owner: geonetwork-devel@lists.sourceforge.net
Priority: major | Milestone: v2.5.0
Component: General | Version:
Keywords: MEF |
Added MEF2 support (see
http://trac.osgeo.org/geonetwork/wiki/MEFImprovement).
Added unit tests for IO operation (MEF, XML and copy/paste).
Added export selection in MEF2 format from search results panel (ie. one
ZIP file with all selected records).
Added uuidAction parameter to the copy/paste mode, stylesheet and category
parameters are now optional (default to none).
Added XML error reporting for MEF service instead of HTML response (Thanks
Simon).
Added delete metadata using uuid parameter.
Fixed parent identifier index fields.
Fixed MEF format parameter label in GAST combobox.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/173>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
